Takegawa Pcx 170cc
sendler2112
Year: 2013 PCX150
Re: Takegawa Pcx 170cc
Post by sendler2112 »
Is that a ridge on the exhaust roller? How is your chain tensioner? I think mine is making a tapping noise.
Pcxdemon
Post by Pcxdemon »
sendler2112 wrote:Is that a ridge on the exhaust roller? How is your chain tensioner? I think mine is making a tapping noise.
No ridge,its smooth to touch but its visible,im not sure why its there or what has caused it...roller spins fine as well.
All of it is coming off soon to do the head so ill have a closer inspection on it.
I havent noticed anything unusual with tensioner, maybe its your valve clearance?
Intake port pic,looks nice and clean in there..
Exhaust port looks bit worrying but on googling about it sounds ok,normal....maybe its running tad lean in top rev,im not sure..
Pcxdemon
Post by Pcxdemon »
Ive just ordered this A/F meter to monitor the mixture and see if it can be improved by upon, costs arm and a leg at this price:
https://www.denniskirk.com/409933.sku?u ... medium=cse
But i got lucky to pick it up at bargain basement price :
http://japan.webike.net/products/21345813.html
So if its running leanish,Yuminashi has made efi adjuster that has two knobs to turn up the fuel volume while road tuning,these two, hand in hand is like match made in heaven... :D
sendler2112
Year: 2013 PCX150
Pcxdemon wrote:Ive just ordered this A/F meter....So if its running leanish,Yuminashi has made efi adjuster that has two knobs to turn up the fuel volume while road tuning,these two, hand in hand is like match made in heaven... :D
It would be nice if Bazzaz made their wide band logging fuel controller for the PCX as the do for the CBR20R. It is completely programmable on the pc.
sendler2112
Year: 2013 PCX150
Pcxdemon wrote:Intake port pic,looks nice and clean in there..
Looks like the intake port could use some polishing.
Pcxdemon
Post by Pcxdemon »
While I'm waiting for the valve springs to arrive, I kinda got bored and decided to buy some plasti dip product and colour the swing arm and trans cover black...I thought if it looks shit house ill just peel it back of and no damage done..I have to say though,the bits looks shit hot in black.
The bracket (not sure it is a swinging arm tbh) looks much better in black. I've been thinking about doing that myself
Pcxdemon
Post by Pcxdemon »
you you wrote:The bracket (not sure it is a swinging arm tbh) looks much better in black. I've been thinking about doing that myself
Bracket it is...swing arm was the first thing that came to my head. :oops: :)
mikelx5
Post by mikelx5 »
really now u had to now i have to paint
DISOBEDIENCE CREW
Same here. It looks like a swinging arm
Stick some stainless bolts into the case cover?
Pcxdemon
Post by Pcxdemon »
you you wrote:Stick some stainless bolts into the case cover?
My exhaust will add enough of S/S to it.... :)
mikelx5
Post by mikelx5 »
i noticed your filter setup did it make any effective difference other than sound
DISOBEDIENCE CREW
Pcxdemon
Post by Pcxdemon »
mikelx5 wrote:i noticed your filter setup did it make any effective difference other than sound
I'm using pod in the box (with the cover on) to reduce pod noise. I would have been happy to use my DNA panel filter in the box but because I'm using 31mm throttle the stock airtube from the airbox was too small to connect to it. Some mods were needed with using larger hose especially plumbing the hose in to the airbox. While I'm fairly certain I have achieved 99% seal around it I figured its a lot safer just runing the pod in there for perfect filtration.
Performance is unnoticeable between open pod and with it in the box but noise reduction is huge though..
mikelx5
Post by mikelx5 »
im looking at doing this i realized i need more air flow after my exhaust did you run a pipe or some connector or was it directly on the hose.
DISOBEDIENCE CREW
wingz
Color: Dark Silver
Post by wingz »
Pcxdemon wrote:
dasshreddar wrote:Very cool Demon 8) How much was that brake arm?
Sorry i missed this earlier..
http://japan.webike.net/products/21133048.html
Cheers
Ah crap, it's gone. What is the the brake arm called so I can search for it?
Subsequent note:
I found this:
http://japan.webike.net/products/21133047.html
Pcxdemon
Post by Pcxdemon »
Thats the one....
chainsaw
Year: 2013 150esp
Color: white/carbon
Post by chainsaw »
Pcxdemon wrote:
chainsaw wrote:yuminashi do have a kit for the 150 that takes it out to 184cc and i remember reading somewhere that they had a 210cc kit in the works
Nope and nope....See the Yuminashi link i provided on a above post to see what avalible for what..
210cc is possible with the 150
Mgalutia88
Year: 2013 PCX 150
Post by Mgalutia88 »
210cc. Now that's insane... 64mm bore by 64.9mm stroke, that's pretty square. It would make plenty of power and rev like a SOB
mikelx5
Post by mikelx5 »
so screw it not gonna baby my motor if it blows its getting this setup
DISOBEDIENCE CREW
