Hello everyone, I'm new to the forum (as a participant, being a reader for a while now) and I have a question I couldn't find in the other topics.
I just bought online a GIVI tall windscreen and a Tucano Urbano handlebar muff. And after 30 minutes I realized I don't know if they would fit together. Does anyone here has both installed? Or someone with the windscreen have an ideia if it works?
Thank you!
PCX125 Windscreen and handlebar muffs together?
Tipover
- Color: Candy red
Re: PCX125 Windscreen and handlebar muffs together?
I have the Honda oem tall windscreen and the Oxford rainseal mitts. The Oxford mitts seem larger than the tucano mitts. I have no clearance issues with my setup.
I do have a Givi tall screen as well. I haven't installed it yet, but, I don't think there will be a problem with my Oxford mitts.
When I installed the tall Givi windscreen on both of our bikes I found that they helped redirect a lot of the wind around the handlebar area, which helped a lot. I also bought hand guards but couldn't find an easy way to install them, since it required taking off the handlebar weights, and those d#%n things won't come off! So, if your handlebar muffs require that you take those weights off, good luck, and let us know how they work out.
