Thank you in advance.
Rear Brakes issue
tinoc32b
Rear Brakes issue
Hello there, hope you can help me out, i have a 2015 honda pcx 150, with 1300 kms, and my rear brakes are doing a strange sound like fine scream, the sound appears when the pcx slow down without braking, i know little about motorcycle mechanics, but i do know that the rear brakes on this model are adjustable, is there any link or know how post.
Re: Rear Brakes issue
Put the bike on its center stand and try to spin the back wheel. If it does not spin without effort then the brake needs adjustment. There is a rod on the left side down by the wheel, just below the center hub. It has a nut on it. If you turn the nut one way it will tighten the cable. If you turn it the other way it should loosen the brake cable. Play with it while using the left hand brake lever to make sure you have not over loosened it since the left hand brake lever applies pressure to the rear brake.
tinoc32b
Thanks Mel46 for your answer, i will adjust the nut first thing in the morning, can you tell me how hard the rear brake lever has to be adjusted, compared with the front brake lever? The sensation of hardness i mean.
I live in Lima - perú, south América, do you know a web site to buy genuine spare parts, mostly for the maintenance? Maybe in USA?
Thank you again
Thank you again
Don't compare the feel of two completely different mechanical brake systems. Although the feeling is remarkably similar the front is disc and the rear is drum. You can find parts when the time comes, what you might want is the parts catalog PDF so as to familiarize yourself to the bits and pieces. A service manual can save you BIG money if you want to learn how to maintain it yourself. When I get back to a computer I can upload a parts cat if someone doesn't do it before. Is your bike LED lights? You have that year that can go both ways.
tinoc32b
Hi homie, thanks for your reply, i have to say that my local dealer is not going to bring the pcx anymore, I have one friend who has the same model, but with 8000 kms and he told me, prepare yourself, brake pads, air filter, coolant change, spark plug, etc etc etc. All hard to find here, and with a waiting list of at least 3 months wich is absurd, unfortunately i dont know anyone else here with a pcx
but i have great chances to get the spare parts with some friends who live in USA and they have family here where i live, only thing is i do not know from where to get the spare parts.
Like i said my pcx is only 1300 kms, but it looks like i have to start looking my spare parts
I see homie you live in Chicago, can i ask where do you get your spare parts.
My pcx is i believe the third version, it have full LED lights, same model as yours, except for the idle stop in my case and the hand brake in yours.
If you can upload that catalog part i will appreciate it very much
Here ya go... I have use Amazon, ebay and all sort of online motorcycle parts outlets. Just depends on the part.
- Parts Catalog Honda PCX150 NEW - 2ND EDITION.PDF
- (7.82 MiB) Downloaded 180 times
tinoc32b
I appreciate it homie
tinoc32b
how about partzilla is it located in USA?
There are several places that sell parts fairly inexpensively on the web. One of them is bikebandit.com however you MUST know what your bike looks like as apposed to the 2013 because the 2013 is ENTIRELY different. There is not a 2014 model in the United States, and the 2015 model has LED lights. One way to tell which is which is to look at the front fenders that keep the wind from hitting your knees. The newest model closed the gap that made sort of a sideways 'V'. In the United States the 2013 model has turn signal stalks right in the 'v'.
My guess is that you have the newer model, so look at the 2015 parts category on bikebandit. Homie has provided you with the catalog. Compare the part numbers with the ones on the OEM page. Here is a link:
http://www.bikebandit.com/oem-parts/201 ... #sch909757
Partzilla.com is another good site.
You can buy spark plugs, air filters and other normal replacement items on Amazon, eBay, etc as long as you know the name and number.
Hopefully, we have helped you keep you pcx running for a long time. They don't require a lot of maintenance but you should have an owners manual so that you now when to change oil. I would change it every 3,000 miles. Use synthetic oil. It is recommended.
tinoc32b
Very sure that my pcx is a 2015 model, sorry about that mistake, on my profile appears 2014, i do not have turning signal on my knees, and i have full LED lights.Mel46 wrote:There are several places that sell parts fairly inexpensively on the web. One of them is bikebandit.com however you MUST know what your bike looks like as apposed to the 2013 because the 2013 is ENTIRELY different. There is not a 2014 model in the United States, and the 2015 model has LED lights. One way to tell which is which is to look at the front fenders that keep the wind from hitting your knees. The newest model closed the gap that made sort of a sideways 'V'. In the United States the 2013 model has turn signal stalks right in the 'v'.
I will check the parts on the OEM page thank you Mel46
About the oil, i didn´t find the JASO MB, i put a MOTUL 10W30 JASO MA2 synthetic is that ok? and my dealer said to change it every 2000 kms wich is in miles about 1250 miles.
- DAB
Motul 10/30 is good, change every 4-5000 miles.tinoc32b wrote:Very sure that my pcx is a 2015 model, sorry about that mistake, on my profile appears 2014, i do not have turning signal on my knees, and i have full LED lights.Mel46 wrote:There are several places that sell parts fairly inexpensively on the web. One of them is bikebandit.com however you MUST know what your bike looks like as apposed to the 2013 because the 2013 is ENTIRELY different. There is not a 2014 model in the United States, and the 2015 model has LED lights. One way to tell which is which is to look at the front fenders that keep the wind from hitting your knees. The newest model closed the gap that made sort of a sideways 'V'. In the United States the 2013 model has turn signal stalks right in the 'v'.
I will check the parts on the OEM page thank you Mel46![]()
To check your back break, put on main stand and turn the back wheel. While moving the wheel put on the brake. Release the brake and turn the adjuster nut until you feel resistance. Release the nut half a turn, test, job done
Other rides
tinoc32b
Thanks DAB, MOTUL is a very good oil, but genuine HONDA oil JASO MB is almost impossible to find, but im sure MOTUL works just fine
My rear brake adjust issue it is done! thanks everyone for the support
Excellent, a good news story
Post a picture of your bike. With a bit of Peru in the background?
tinoc32b
sure thing, i will post a pic of my pcx
he's going to need a variator kityou you wrote:Post a picture of your bike. With a bit of Peru in the background?
I WANT TO RIDE ONE!
- peru.jpg (10.08 KiB) Viewed 3864 times
- love.jpg (4.96 KiB) Viewed 3864 times
I love llamas, and alpacas.
tinoc32b
JAJAJAJAJAJAJAJAJA
i´m sorry, but i hate lamas, bad experience ... they like to spit ... a lot
tinoc32b
I have a few pics of today of the pcx in Lima - Perú, sunny day !!!
Located in San Borja today 10:00am
I have a video to show you all the rear brake adjustment i perform yesterday
But i can´t upload the video, can someone tell me what´s the correct extension, i alredy tried with AVI, WMV, MOV
- tino 4.jpg (1.16 MiB) Viewed 3833 times
- tino 1.jpg (1.45 MiB) Viewed 3833 times
tinoc32b
OH and 1 of my rear brake
- tino 5.jpg (990.7 KiB) Viewed 3832 times
Nice bike
but we can't see it and i'm on a 24" monitor
If you are windows based use the paint program to resize your images or program your camera to store smaller pictures OR just use your cell phone and email to yourself, save to drive, and then upload to forum
As for video make a youtube account, upload your vid to YT, open the video from (my channel, video manager) copy the address string in the text block and paste in forum. Like this;
https://www.youtube.com/watch?v=rczZE_4OBJI
or just past the tail end of it after the =... rczZE_4OBJI
then highlight it and click the [youtube] box up by the font tools.
I WANT TO SEE A LAMA!!!!!
- tino 4.jpg (195.01 KiB) Viewed 3827 times
