Speedometer, odometer and idle stop not working
Hi
I have owned my pcx125 for nearly 12 months. Bought 2nd hand from a Honda dealer.
Couple of weeks ago speedometer acting erratically jumping from 40 to 60 when not changing speed at all. All this when raining
Weather dries up and all working fine.
Few days ago again when wet speedo and odometer and idle stop all stopped working but this time no coming back whatever the weather.
Checked speedo sensor and looks ok.
Any ideas
Thanks in advance
Any ideas
Thanks in advance
- Alibally
Re: Speedometer, odometer and idle stop not working
I'd be checking all the electrical plugs first. There's a load of a them if you take the screen and the black cover under it off. Also check the connection at the speed sensor for water ingress. It might be a bit of wiring chaffed through or a bad earth contact..
You might have to take the plastics off to gain access to the instrument wiring to check it.
The idle stop won't work without a speed signal as it won't know when the bike is stationary.
Sent from my iPad
Sent from my iPad
Great. Got Friday off so going to have a proper look then
Thanks for the swift reply
- Alibally
Your looking for corroded or wet connector plugs. To test the speedo, start the bike up on the centre stand then give it a rev. If you can't find anything obvious you might need to get your bike garage to have a look.
Sent from my iPad
Sent from my iPad
Where will I find these connector plugs
From a previous post....
"There's a load of a them if you take the screen and the black cover under it off. Also check the connection at the speed sensor for water ingress."
When I turn the bike on the speedo DOES flick round to 100 then back to 0 so there is power
Any more ideas from this
- Oyabun
- Year: `12,`15,`19
- Color: black&black
I'd check chassis grounds.
Failing more than circuitry at the same time is usually a ground problem especially if the issue has started to act up in rain.
Search for my posts- i recently started a thread to warn about such a potential issue.
Also please fill in your location, year and color of your scoot.
The vintage information could be hany to give further advise (eg. The LED models have an additional connector set to separate fhe engine from the chassis which could be also problematic - but the 2011 model cables are directly connected to the ECU.)
I had the same issue on my 2013 it turned out to be the wire that goes to the speed sensor. Try removing the air box and testing the wire running underneath it.
Honda forza 125 2019
Yellow malossi contra spring
Malossi delta clutch and bell
Malossi special kevlar belt
K and n air filter
Akrapovic exhaust
Malossi White Contra Spring
Malossi yellow clutch springs
Daytona reinforced belt
DNA Performance air filter
Removed air box flange
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
Taken the air box off and can't see anything wrong
