Forum Suggestions
Re: Forum Suggestions
I use Tapatalk on my droid.  Very good format for the phone and quick and easy to see all the new posts you have yet to read.
Sent using Tapatalk
									Sent using Tapatalk
What is the error it is giving you? The image has to be under 120px x 120px, and below a certain size (limiting you to .jpg, .gif, and .png images).alleykat wrote:I haven't been able to load an avatar no matter if it was the correct size.I'll just keep trying though.
If you want to add the image you're trying to make your avatar as an attachment, I can look at it and tell you why it won't work.
Currently ride:  Nothing right now - mostly mountain biking with my boys until they're old enough to ride
Sure, I'll look into that this afternoon.
Just bought it yesterday as i saw you were using it. Glad i did nowTC3 wrote:I use Tapatalk on my droid. Very good format for the phone and quick and easy to see all the new posts you have yet to read.
Sent using Tapatalk
Editing is enabled 5 minutes after posts, to prevent bait-and-switch... On the old forum, the admins would say something, then edit their posts after people responded, making those who were responding look like they were flaming on Corsport for no reason. It also helps keep people honest and prevent flame wars, because what you say is stuck there.TC3 wrote:Can not see an option to edit my posts?
Hmm if I had a choice I would want to be able to edit a post for changing info or maybe add a pic or the such but its your forum so your rules.
Sent using Tapatalk
									Sent using Tapatalk
It can be kinda annoying, but it helps to add some accountability to your posting.TC3 wrote:Hmm if I had a choice I would want to be able to edit a post for changing info or maybe add a pic or the such but its your forum so your rules.
Sent using Tapatalk
Speaking of annoying, would you care to filter 'Sent using Tapatalk' out of the posts? I guess the tapatalk users themselves can't disable it (at least in the free version?) but me thinks you should be able to filter it at the forum level? Or is that against the license or something?
I think I can remove it. Let me check...
Just add another post!TC3 wrote:Hmm if I had a choice I would want to be able to edit a post for changing info or maybe add a pic or the such but its your forum so your rules.
Sent using Tapatalk
Updated, shouldn't say Sent using Tapatalk anymore
Sent using Tapatalk
									Sent using Tapatalk
Youtube embedding should work. Let's test...
Use only the data after the =. For example,
 yields this result:
Code: Select all
[youtube]1lyu1KKwC74[/youtube]Currently ride:  Nothing right now - mostly mountain biking with my boys until they're old enough to ride
I know it can on your end, but it should be able to get toggled from my end (which I changed). Did you have to change it from your end?
I also added a few other bbcodes when I added youtube tags, including google video
your mom is fat
text centered
text left (WHY!? THIS DOES NOTHING!?) I'm leaving it though.
text right
And spoilers (highlight the below text to see it)your mom is fat
- haildamage
i gotta agree that it is better to be able to edit instantly. most people arent gonna be jerks on a forum like this and just make flaming against the rules.
