2015 PCX Valve Clearance Adustment
This will be a long piece of work in video, Please restrain from comment and it will read better for those who want to do their own valve clearance adjustment on a 2015 Honda PCX 150. If not them maybe Maddie will clean it up when its done.
Session 1 - Side Panels and trim clips
Tips & Parts; http://www.amazon.com/Plastic-Screw-Riv ... Y6V0368DE3
Place a rag over your side stand (in the down position) when popping the trim clips to avoid nicking your paint on the left side panel.
Keep an eye on your screw fasteners they like to flick away. The side panels are quit secure without replacing the two trim clips.
- side panels.jpg (44.62 KiB) Viewed 8163 times
Re: 2015 PCX Valve Clearance Adustment
Manual would have you removing body panels in this session but if you don't know exactly how to hold your mouth this could make for a long day so take the luggage box out first as in the next video then all will make sense as you have a much better view of body panel connections.
Session 3 - Grab Rail - Luggage Box & Body Panels
Tips: Trim clips remove very nicely and can be reused if you use the plastic cowling/fairing tools. http://www.amazon.com/Panel-Window-Mold ... oval+tools
Be patient with the body panel removal, the tail light assembly removes with both panels at the same time.
Session 4 - Battery Box & Cylinder Head Cover Removal
Tip; Probably want to take care with the rubber seal, there will be torque specs for these 4 bolts at the conclusion.
Session 5 - Timing & TDC (top dead center)
The one on top is intake .004 +/- .001
Click on youtube and then to full screen and leave this thumbnail size video for the detailed HD
Session 6 - Adjustment
Intake was found to be just under .003 in.
Exhaust just under .008 in.
Both Valves are consistent under spec with a cold engine, rotated the crank shaft several times to be sure and there is nothing here to see. Apparently I'm growing into perfect specification or already there with a hot engine so I won't be doing this again any time soon
Seems Honda was having a good day when they built Shay Whitey. Time to put her back together before I forget how
I will follow up with torque specs and any goofiness that occurs during reassembly only if there is something new to learn in the process. I need to find some gasket goop and the manual doesn't offer a brand so any suggestions would be helpful. May take a couple days to reassemble as I see a little dirt under these panels and you know how that will bug me
In review I note there was no reason to remove the crank case cover on the left side. I assume it was to place a socket and turn the crank shaft for timing and I used my thumb on the fins instead (one person method).
Also you could remove the body panels without removing the luggage bucket if you knew exactly what was going on under all that plastic but for a first time rookie like me... it worked out better.
Here is a picture of the point at which you check the clearances and I do note there will be no actual adjustment footage because SORRY I don't need one
However if you did need a little tweak there are special tiny wrenches involved that someone should show you in this thread. There are square flats on the stem and one lock nut. Loosen the nut turn the flats to achieve desired clearance then lock it back down while holding the flats on the stem in position (thus the special wrenches). Tappet wrench 3mm 07908-KE90000 (USA ONLY)
Cylinder head cover bolts torque spec was not provided, but use common sense and make them snug.
- .003.jpg (165.74 KiB) Viewed 8136 times
I should finish this with as much info as possible without loosening the lock nuts. Not sure what the lock nuts torque to but I will check the manual.
- dasshreddar
- Year: forzaruckuspcx
So you did all that and didn't even adjust them??? only needed .001 more... come on, you can do ithomie wrote:Session 6 - Adjustment
Both Valves are consistent under spec with a cold engine, rotated the crank shaft several times to be sure and there is nothing here to see. Apparently I'm growing into perfect specification or already there with a hot engine so I won't be doing this again any time soonSeems Honda was having a good day when they built Shay Whitey. Time to put her back together before I forget how
I don't use any "gasket goop"... as long as the gasket is smooth, clean/lightly oiled and torqued evenly... it wont leak.
Even though I could tear apart a pcx with my eyes closed... I still enjoyed watching your videos, thanks.
"what a mess"
Thanks for al that Homie! Makes sense to remove the seat well for added easy of access.
Excellent tutorial! Are you using the Mobius?
iceman wrote:Thanks for al that Homie! Makes sense to remove the seat well for added easy of access.
Coming from a pro I consider your interest in this an honor. SM shows the sealer and where to put it so since I have it. But you are right it doesn't look like it would need it. And its just in the corners as shown.dasshreddar wrote: So you did all that and didn't even adjust them??? only needed .001 more... come on, you can do it![]()
"what a mess"![]()
- image3.jpeg (67.73 KiB) Viewed 8097 times
- image2.jpeg (42.25 KiB) Viewed 8097 times
- image.jpeg (20.1 KiB) Viewed 8097 times
you are most welcomeiceman wrote:Thanks for al that Homie! Makes sense to remove the seat well for added easy of access.
absolutely!.. brought to you by Mobius action cams, is why it took 12 hours to do the job, It will go back together fasterSECoda wrote:Excellent tutorial! Are you using the Mobius?
I am glad my Forza doesn't need one until something like 16,000 miles I think (I still need to study that maintenance schedule).
You have convinced me to take my PCX to the dealer for the valve check now that I have the Forza to keep riding.
This monkey business is certainly not for everyoneSECoda wrote:Well if you can keep it under 20 hours that works out to about $7.50 /hr (@ $150 valve check/job). You beat the Federal minimum wage of $7.25.The fun is worth so much more though. You have convinced me to take my PCX to the dealer for the valve check, What a pain.
- Steph
- Year: 2013 150cc
- Color: Black PCX
Cool videos Homie. I watched all of the them. I got 3500 miles on my scoot now. Hope my valves hold out for a bit more.
How many times have you had them checked? Just curious so I can feel better about the effortSteph wrote:Cool videos Homie. I watched all of the them. I got 3500 miles on my scoot now. Hope my valves hold out for a bit more.
Get after this before it drives you insane... some silliness you might want to avoid.
- Steph
- Year: 2013 150cc
- Color: Black PCX
Never had the valves checked.
I am contemplating the 2500 mile valve inspection at the dealer for the PCX since I have the Forza to ride. They always run coupons so I am hoping to get 15% off of the $150 they said the valve adjustment runs.
After watching them take apart the Forza for a while I have no qualms about letting them work on the PCX. I already bought an air filter if it needs it and have no problem changing/cleaning the oil/strainer and other inspections. I have a walk-out basement with a work shop indoors so it is always room temperature.
