Here is what is available from a Forza 300 and you can still ride it to work!
![Image](http://i152.photobucket.com/albums/s170/mikerust/HondaFORZA300_zps3c4fe1cb.jpg)
Red line is Stock
Blue line is with aftermarket exhaust (in this case J Costa)
Beige line is with J Costa variator and the exhaust.
Horsepower is only a calculation and I'm not sure the trace below is a curve.blackcat54 wrote:So... the exhaust does virtually nothing to improve the performance of the HP curve.
Yes the exhaust does contribute just that the stock variator obviously does not allow it to do so.blackcat54 wrote:So... the exhaust does virtually nothing to improve the performance of the HP curve.
The variator however makes a big difference!
Too bad you didn't post the variator curve alone (with the stock exhaust).
Well that is not a fixed gear Dyno curve like conventional motorcycle, tested in one gear, would give.you you wrote:Horsepower is only a calculation and I'm not sure the trace below is a curve.blackcat54 wrote:So... the exhaust does virtually nothing to improve the performance of the HP curve.
