Booked a lodge back in January in hopes of finding a little warmer climate than up North, but like the rest of the nation, everything is 3 weeks behind from normal temps.
Arrived Thursday night after a shitty drive through Cincinnati. I can usually pull it off in a little more than 8 hours, but Dayton to Covington took over 2 hours. That should have been 40 minutes tops!
Anyway, Friday morning was quite cold but the road called my name. The road to the lodge was quite steep and same with the parking on a grade. I did end up using the parking brake...lol
Here's the view from the upstairs balcony
Everything West of the main drag going into Pigeon Forge/Gatlingburg is up the hill and houses built into the hill side. I really wasn't sure if the PCX could handle such a grade, but it did and then some.
Do to the low temperatures I just milled around the outskirts. I took the Gatlingburg bypass into the Park. Quite scenic as it always is, but being on 2 wheels made it really special. It's easy to pull off and take pics.
I love running water and that will become appearant if you choose to read on. Must be the flyfisherman in me....
The views are spectacular and can't be matched looking out of a car window. You're in it and a part of it!
It's the little things that grab your eye...
