Worsening oil leak leads to valve check
mymitzi
Post by mymitzi »
The PCX has been using oil for a long time but it's gotten worse, lately. Have to add every 200-300 miles. Knew it was probably coming from the
Valve cover, as it was dripping on the exhaust header. Never any evidence on the garage floor since it vaporized on the exhaust. Bit the bullet
and decided to fix it...and do the valve check while in there. [first one] The scooter runs as well as ever. Even so, The valves were spot on! Wasn't
expecting that. Went ahead and cleaned the valve cover/ gasket and put the sealant where recommended and buttoned it back up. Letting it
sit till tomorrow to give the sealant time to cure. Still amazed that valves needed nothing. Think I'll keep her, even if it didn't cure the leak. : )
mymitzi
Re: Worsening oil leak leads to valve check
Post by mymitzi »
An addendum to the above. Know that it's hard to believe....I'd be right with you had I not "lived it". Pretty confounding..... Needles to say,
That will be my last valve check. This PCX will be with me till one of us dies!
Conelite
Color: Blue
Post by Conelite »
How many miles on the bike?
I have over 7k miles and never had to adjust the valves once. Spot on at 6k.
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
mymitzi
Post by mymitzi »
Conelite
Color: Blue
Post by Conelite »
95k Miles? HOLY HELL!!!!
I think you got your moneys worth lol. Never seen a PCX with over 50k.
2017 PCX 150
Z-Bars
NCY Variator
mymitzi
Post by mymitzi »
There was a guy over in Greece that was on here a few years ago that had way more miles. He had done some serious modifications [maybe a rebuild] But the Honda Helix is also known for topping 100k , no problem. They filter the oil with a thimble screen also. What amazed me, was finding the valves didn't need to be touched! Pretty sure the leak is fixed but time will tell.
mymitzi
Post by mymitzi »
Was wondering if the "Roller rocker arms" might have been a factor in the maintaining of the valve settings. I'm quite sure my checking was valid.
Accepted,004" in the intake, 006" unaccepted. The 009" accepted in exhaust, 011" unaccepted. No obvious evidence of oil leaking, but it appears
it is still going somewhere?? Not going to obsess about it since it's been using oil from day one. Still runs very well though.
pcx888
Color: pearl white
Post by pcx888 »
I have over 65k on mine running strong and hard.
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
mymitzi
Post by mymitzi »
Does yours use oil between changes? Mine still uses quite a bit. Wish I knew where it is going?? Not out the exhaust, and no obvious leak.
mymitzi
Post by mymitzi »
Well Guys, Old Faithful made to 100k. [Had 2,092 miles at purchase] Still running fine. Over the years, have had around 2 dozen Motorcycles, and
enjoyed each one, but the PCX is my favorite. Have a Forza too......fine scooter, but the PCX gets the miles. Honda got it right. Except for the valve
check interval. : )
