I would like to install this GPS - it has 4 wires shown in the wire diagram image. But where can I connect the ACC line? I have attached a photo of the batter compartment. Where can I attach ACC wire?
How to install GPS Tracker - SinoTrack ST-901L
TikiTorture
- Year: 2023
- Color: Grey
- unnamed.jpg (73.54 KiB) Viewed 42070 times
Martin J
Re: How to install GPS Tracker - SinoTrack ST-901L
I just connected red and black to the battery terminals and tucked it down the side of the battery.
It worked OK, but would drain the battery if not used for a few days. In the end I did away with it and bought a huge chain instead.
Yamaha 900 Diversion '96
Suzuki GS550E '81
Benelli TRK502 '21
Honda PCX 125 '18
Suzuki GS550E '81
Benelli TRK502 '21
Honda PCX 125 '18
You are better off hiding an air tag. This is going to drain your battery since it has to constantly be getting power.
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Z-Bars
NCY Variator
RandalllFlaggg
- Year: 2022
I use a Tracki. With the extended battery, it lasts about 3 weeks before swapping it out. $20 a month for the service.
https://www.amazon.com/dp/B07YVNV82V?re ... in_title_2
