Is this an oil leak?
150pcxer
Color: Silver
Post by 150pcxer »
Hi all,
It appeared after starting the engine for a few minutes for the first time of the day after being left overnight.
There is also a burnt smell while the engine runs.
springer1
Year: 2018
Re: Is this an oil leak?
Post by springer1 »
What’s the oil level look like? Put a bit on your fingertip - if it tastes sweet it’s coolant. Have you done any work to the scoot recently ?
150pcxer
Color: Silver
Post by 150pcxer »
springer1 wrote: Sat Jul 17, 2021 7:25 pm What’s the oil level look like? Put a bit on your fingertip - if it tastes sweet it’s coolant. Have you done any work to the scoot recently ?
Recently changed to a new stock clutch, that's all.
I went to the workshop and was told that there was a problem with the "cam cover gasket", causing the leak and bad smell. Not sure if he meant the valve cover gasket.
Will be going to another workshop for another opinion.
springer1 wrote: Sat Jul 17, 2021 7:25 pmif it tastes sweet it’s coolant
If it doesn't taste sweet, its carcinogenic.
Never stick vehicle fluids anywhere near your mouth.
Or other bodily orifices.
Conelite
Color: Blue
Post by Conelite »
Simply judging by all the burned oil on the header, you probably do have a leak.
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
