Steering head stock
40jack
Steering head stock
Post by 40jack »
Any one had problems with loose head stock? Anyone had a go and tightening it?
I've read that it's an issue with the forza specially on the UK roads.
Re: Steering head stock
Put it on centrestand and lift the front wheel off the ground by jacking it underneath somewhere or getting someone to lean on rear seat.
Turn the handlebars left and right.
If there's any notchy feel, particularly at the straight ahead position the bearings are screwed and need replaced.
Nightmare of a job due to bodywork removal.
Mine went 30-odd thousand miles without any adjustment needed.
40jack
Post by 40jack »
gn2 wrote:Put it on centrestand and lift the front wheel off the ground by jacking it underneath somewhere or getting someone to lean on rear seat.
Ah right good to know... So after yours went did you simple tighten it or replace the bearings?
What makes you think mine went?
Gil
Post by Gil »
My PCX started making a knocking sound when coming to a stop at about 20,000 miles. The noise only got louder and happened more often. The bearings were good though, no binding like gn2 mentioned. After doing it the hard way of removing all the plastics and the handlebars to get to the top nut, I think there's an easier way. Since we aren't servesing the bearings, only tightening down the tension nut a bit.
You might be able to just remove the dashboard plastic covering the steering stem. Then you need to loosen nut number 3, just a bit. Then go about adjusting the tension on the bearing with nut number 11, like states in the workshop manual. Admittedly, I ended looking up some YouTube videos on how to adjust the tension on those bearings. After the tension is good, tighten down nut number 3.
After I adjusted it, the problem hasn't returned. Good luck
40jack
Post by 40jack »
gn2 wrote:What makes you think mine went?
Ah sorry lol... I read it wrong, I thought you meant it was 30 000 miles before it went.
40jack
Post by 40jack »
Gil wrote:My PCX started making a knocking sound when coming to a stop at about 20,000 miles. The noise only got louder and happened more often. The bearings were good though, no binding like gn2 mentioned. After doing it the hard way of removing all the plastics and the handlebars to get to the top nut, I think there's an easier way. Since we aren't servesing the bearings, only tightening down the tension nut a bit.
Thank you for that.
