Oil drain plug
HondaC110
Color: Bronze
Oil drain plug
Post by HondaC110 »
Does anyone know the dimensions for the PCX drain plug? It's a 2019, though I don't think that should matter. Looking for diameter and pitch, primarily. Thinking of installing a Fumoto valve.
Thanks!
Year: 26 adv 160
Re: Oil drain plug
HondaC110 wrote:Does anyone know the dimensions for the PCX drain plug? It's a 2019, though I don't think that should matter. Looking for diameter and pitch, primarily. Thinking of installing a Fumoto valve.
Thanks!
Install a Stahlbus valve, not fumoto, I tried both. The fumoto sticks out too much. I’ll look at my notes for size.
HondaC110
Color: Bronze
Re: Oil drain plug
Post by HondaC110 »
Thank you!
Year: 26 adv 160
Re: Oil drain plug
M12 x 1.5 is what you want
relic
Color: red white
Re: Oil drain plug
Post by relic »
These guys are also good. I have one installed on my Cummins 15 litre, 14 years later and many changes, works flawlessly.
https://www.nospillsystems.com/index.cfm
Re: Oil drain plug
relic wrote:These guys are also good. I have one installed on my Cummins 15 litre, 14 years later and many changes, works flawlessly.
Let’s have a picture of the Cummins?
easyrider
Color: blk
Re: Oil drain plug
Post by easyrider »
The only problem with those quick drain valves is the size of the drain hole. In the case of the stahlbus the ball valve only opens a tiny bit. Albeit enough to flow oil but does it allow a good flow or flush allowing the elimination of bigger particles. On a scooter I don't think it matters that much but on a car or vehicle I think a larger opening would allow more velocity and pass bigger particles to the drain pan.Just a thought.
Re: Oil drain plug
easyrider wrote:The only problem with those quick drain valves is the size of the drain hole. In the case of the stahlbus the ball valve only opens a tiny bit. Albeit enough to flow oil but does it allow a good flow or flush allowing the elimination of bigger particles. On a scooter I don't think it matters that much but on a car or vehicle I think a larger opening would allow more velocity and pass bigger particles to the drain pan.Just a thought.
It is just a thought. They work just fine.
relic
Color: red white
Re: Oil drain plug
Post by relic »
Here you go you you, a 15 litre Cummins, when I pull the drain plug have to deal with 44 litres of hot oil pronto.
The drain valve makes that easier to manage.
relic
Color: red white
Re: Oil drain plug
Post by relic »
Since i had the the bike, the truck and the camera all together at one time, thought I may as well include this photo.
easyrider
Color: blk
Re: Oil drain plug
Post by easyrider »
Not only a thought its a restriction in the drain port.You are reducing velocity of flow and reducing the diameter by 75 percent in some cases .This smaller drain opening inhibits the removal of larger particles.They may allow the draining of liguid oil just fine but while leaving larger contaminants behind.Make sure you use a good oil filter when using this type of valve.I dont think its a big deal however on a small scooter engine
Re: Oil drain plug
relic wrote:Here you go you you, a 15 litre Cummins, when I pull the drain plug have to deal with 44 litres of hot oil pronto.
Cheers. I’ve had a good stare at it :) :)
Re: Oil drain plug
Nice picture with the hills in the background as well! :D
Looks like a great area for riding the PCX. 8)
