Tubeless Tire Re-inflated Using Tourniquet Method
PCX150Rider
Post by PCX150Rider »
I found the "Tourniquet Method" to re-inflate a flat tubeless tire (for smaller tire sizes like garden equipment and scooters) to be quite useful today and my efforts resulted with success. :D
Originally I was going to start some work on my KLR 650 but that got put off t'ill tomorrow. :roll:
My wheelbarrow takes a 480/400 - 8 tubeless tire. The tire on it had totally deflated over time from non-use due to circumstances. About a month ago I turned it upside down to allow the rubber time to restore it's shape and now that the weather is much warmer I figured it would be a good time to try and see if I could inflate it again.
Much to my surprise and elation my efforts worked and it didn't take that long. The pictures below were taken after I actually got the tire to seal on the rim and hold air. As an added note there is also a video on YouTube that shows this method being used as well. :geek:
This pic shows the basic layout of the rope and hammer handle I used to tighten down on the tire and force the walls to seal against the rim. I basically tied an overhand knot somewhat firmly and then positioned the hammer handle inside another two half hitches knot. I started rotating the hammer handle, keeping the rope in line on the wheel, and tightened until the walls were against the rim. :o
Next, you will see the tire is now inflated. When I was adding air from my compressor line I gradually released the tourniquet pressure slowly and let the tire return to it's normal inflated condition. The compressor was set to 30 PSI and I used my tire gauge to set the tire pressure at 24 PSI. . . adequate for practical use. 8)
Finally, since the tire is really old and showing some dry cracking, I added a dish soap and water solution to see if I could detect any apparent bubbles from leaks. It was fine. Rather proud that I just saved myself some money and will kick this can down the road another few miles. . .. :D
Along the way I've read about other scooter riders using this method as well and figured I'd try it on my wheelbarrow as a practical lesson. That said, when it comes time to replace the tires on my Genuine Roughhouse R50, I may try to mount them myself and get them inflated this way. :geek:
Hope this helps and if anyone else needs to fix any garden equipment wheels or maybe try it on a scooter here's the video I got my info from. ;)
relic
Color: red white
Re: Tubeless Tire Re-inflated Using Tourniquet Method
Post by relic »
I see now tire shops are using a water soluble grease to seal heavy truck tires for inflating, sure beats the previous methods of spraying ether and igniting it, rubber O rings and tire blasters.
Simply apply the grease around the bead inflate and scoop the excess up and put back in the can for next time.
relic wrote:I see now tire shops are using a water soluble grease to seal heavy truck tires for inflating, sure beats the previous methods of spraying ether and igniting it, rubber O rings and tire blasters.
I've seen the igniting method o_O
Seen it done using a big ratchet strap rather than rope.
easyrider
Color: blk
Post by easyrider »
gn2 wrote:Seen it done using a big ratchet strap rather than rope.
Me too.
Job well done.. and a feeling of accomplishment. YES!
