PCX Speedo inaccuracy
- alx123
- Bangkok Rider
- Color: Fast White
For two days now I am using a GPS speedo app to check accuracy of the PCX.
Consistently, it seems that the stock PCX speedometer is 10% more optimistic than the actual speed.
It means that if I am running 110kph (68.3 mph), I am just actually running around 99 kph (61 mph).
I am using the app named DIGIHUD. https://play.google.com/store/apps/deta ... ihud&hl=en
Can anybody from Europe and US check if this inaccuracy is consistent? Your PCX there might be calibrated differently, since your'e using MPH instead of KPH.
I just learned that most ,if not almost all, motorcycles are calibrated this way. Which is quite puzzling to me.
Brent
Re: PCX Speedo inaccuracy
I have not found my speedometer to be off under 40 mph. I make it a habit to drive past known automatic radar stations to see what the station says my speed is vs. what the speedometer says I am going. My speedometer was on within one mile per hour at 25mph, 30mph, 40 mph, and 50mph. The speedometer is a dial gauge, and it is not possible to see the exact speed; but the two speeds were close enough for me to consider my speedometer accurate!
What I have found is that the speedometer is off by up to 10% until I reach 45 mph. Then it is right on the money. There have been multiple threads on the accuracy of the speedometer and the consensus seems to be that the models sold in the United States are more accurate than in other countries. That may be so because of stricter requirements here. No motorcycle that I have ever owned has had a speedometer that was off.
Is this going to be like the lawn mower hp wars that ultimately ended in one maker getting busted for exaggerating the displacements with decals stating inaccurate information. They were simply putting 6hp decals on 4hp engines. I think Honda is careful not to state a top end speed for the scooters. Have we seen any advertizement or brochure claiming the max speed for our scooters? Any mention in the owners manual? Honda is quick to quote mpg regardless of rider weight and other conditions but top speed...? I don't recall seeing it but I could be wrong about that. My bike has oversized tires so my speedo is off for sure or I would go and do a comparison test with my app against the dash.
- alx123
- Bangkok Rider
- Color: Fast White
Hope someone with stock new pcx 2015-17 can do the same using the same app(DIGIHUD), just for comparison.
At 20kph im only 2kph(10%) faster so it is not that notiCeable. But as I go faster the 10% become so evident.
If you search online or in some forums, almost all bikes are complaining of inaccuracy. Cars they say are more accurate. Why would manufacturers do this is beyond me.
They might be getting away with something like this for years. Could be a conspiracyalx123 wrote:If you search online or in some forums, almost all bikes are complaining of inaccuracy. Cars they say are more accurate. Why would manufacturers do this is beyond me.
- alx123
- Bangkok Rider
- Color: Fast White
I've read it's actually a regulation (UN), but for what purpose I dont know.
I Might just cover my entire speedometer and regard it as useless and install a gps one. LOL
- sendler2112
- Year: 2013 PCX150
The Honda world bikes in the USA have speedos which are pretty much dead on. Most other markets get speedos which are intentionally high by 8% to appease the lawyers and insurance companies so that no rider can ever argue that they crashed because they were going faster than what the speedo displayed. It has been like this for decades all over the world. Silly game.
HA! conspiracysendler2112 wrote:The Honda world bikes in the USA have speedos which are pretty much dead on. Most other markets get speedos which are intentionally high by 8% to appease the lawyers and insurance companies so that no rider can ever argue that they crashed because they were going faster than what the speedo displayed. It has been like this for decades all over the world. Silly game.
- alx123
- Bangkok Rider
- Color: Fast White
Can I sue Honda telling them i know the speedo is inaacurate so I tried to run faster?
There are roads with miNimum speed required, and I migh tbe in trouble if my speedo is inaccurate.
SMH
Now, is someone kind enough to test their pcx using the same app to see if it consistent with all pcx or Mine is just factory defect? I might have good reason to go Honda and tell them to recalibrate my speedometer.
SMH
Scoot Commute
- Year: 2012
On my 2013 model i can say if anything is accurate it is that it always reads 10% below actual current speed
- djbass
- Year: PCX150, 2015
The speedometer is lying. Today, once again measured the speed, mileage, when traveling with a country house. For speed increases 10%, the mileage lowers to 5%
- very surprised. The speed was checked via GPS and odometer readings relative to the machine. Fuel consumption turned out to 2.2 l/100km as passport, was moving on the highway about 90km/h on the speedometer and about 70km/h in the city. Real consumption is measured by filling up to full tank and the flow rate coincides with the on-Board computer scooter.
Data for the month of June - consumption of city - 200km, the rest of route: 44,2 km/l or 2.26 l/100km
And today's ride track and a little town: 45.2 km/l or of 2.21 l/100km
At least the PCX150 is very stable which is good!
- alx123
- Bangkok Rider
- Color: Fast White
thank you. So the 10% discrepancy is confirmed (in kms).djbass wrote:The speedometer is lying. Today, once again measured the speed, mileage, when traveling with a country house. For speed increases 10%, the mileage lowers to 5%- very surprised. The speed was checked via GPS and odometer readings relative to the machine. Fuel consumption turned out to 2.2 l/100km as passport, was moving on the highway about 90km/h on the speedometer and about 70km/h in the city. Real consumption is measured by filling up to full tank and the flow rate coincides with the on-Board computer scooter.
Hope someone in (mph) can do the test and give us the %.
I dont worry much about the fuel mileage, the pcx is very efficient for a 150cc.
Thanks again for the info.
- sendler2112
- Year: 2013 PCX150
- djbass
It is very good. Another would be the photo for emphasissendler2112 wrote:is 0% speedo error.
- alx123
- Bangkok Rider
- Color: Fast White
gps test?sendler2112 wrote:My USA 2103 PCX150 is 0% speedo error.
- sendler2112
- Year: 2013 PCX150
I've done it before but didn't shoot a video. It's dead on. And so was my CBR250R. All of my other USA bikes read fast. I haven't really checked the R3 yet.
- raito
- Color: matte silver
@sendler2112 Is your PCX 2013 stock? What is your top speed indicated by your speedometer?
I found a lot of non-US PCX top speed videos on Youtube, but couldn't find a US one. I found this textual statement for a PCX150 2013:
My stock PCX150 2015 GPS top speed is 104kph with my speedometer indicating about 110kph. I took a video and will share here once processed and uploaded.http://www.justgottascoot.com/hondapcx.htm wrote:Surprise, surprise, the Honda PCX 150 is very nearly spot on in speed and distance. The VAST majority of scooters we test are optimistic to the tune of 10% - 15%. Not so with the PCX, at an indicated 30 MPH the actual speed was..... 30 MPH. At 40 MPH indicated the actual speed was 39 MPH and at 50 MPH indicated the actual speed was 48 MPH. The Honda PCX 150 is ever so slightly optimistic. The odometer was right on with our actual test of 11 miles indicating 11 miles. The top speed I saw on the GPS was 63 MPH on a level surface.
- Lanesplitter
Mine too, but it's not a 22nd century bike. ;-)sendler2112 wrote:My USA 2103 PCX150 is 0% speedo error.
My V-strom is off (over states speed) by 5mph under 65mph and gets worse above. Odometer on it seems off by 5%, on the high side.
- sendler2112
- Year: 2013 PCX150
My PCX is no longer stock. I installed 11gm DrPully sliders and new OEM variator, face, and belt at 12,000 miles and now the top speed is 69 mph indicated at the rev limiter. Up from about 65 when it was new and 62 with a worn belt.raito wrote:@sendler2112 Is your PCX 2013 stock? What is your top speed indicated by your speedometer?
