Just picked up a 2017 PCX150. Rides great. What are some must have accessories for this? I am thinking to start off a taller windscreen would be great. Perhaps a top case? I had a 2013 before and on this one seems there is a panel to remove to install the top case instead of drilling into plastic of previous generations.
I heard there is a way to install a spring in the seat to allow it open completely with the push of the button.
New PCX 150
Re: New PCX 150
To help us help you better, could you list your location as a part of your profile?
Indeed, the panel at the back eliminates the need to drill when installing a top case.
A couple of years ago I recall seeing a post on here where someone was able to purchase a spring loaded seat hinge. Keep searching, you will likely find it.
- riding@100mpg
- Color: red
Re: New PCX 150
i installed the tall givi windshield on my 2016 pcx and it works great when it's cool out. good protection and no buffeting on my helmet. i can ride with the face shield up with no problem. i can just see over the shield but i am on the short side,about 5ft 7 inches on a good day. also put a top box on the back. i have several motorcycles and a vespa 300 but seem to use the pcx the most. it loves the twisties and back roads. good luck with yours.
Summicron
Re: New PCX 150
Foam grips and the middle sized National Cycle windshield
Also I like the Alaska Butt Pad (Sheepskin pad)
Jim
Jim
Re: New PCX 150
I ordered a tall Givi screen , now trying to see which Givi top case would be appropriate.
Re: New PCX 150
and....did you choose? Curious minds want to know
- riding@100mpg
- Color: red
Re: New PCX 150
I have the tall giving windshield if you're interested. Just traded my 2015 pcx150 and kept the windshield off it, let me know and ill make you a great deal if you're in the us
- Year: 26 adv 160
Re: New PCX 150
A Ton of mods in the thread in my signature, it’s pretty much everything I’ve done to the bike…
