I reused the original belt and sliders for consistency, so I had a good back to back comparison with what I've been running up until now.
The bike now hits 139kph on the centre stand instead of 120kph (119kph on road) with the stock variator, drive face and rollers.
The Daytona variator is a high quality looking unit with black painted finished on the inside, and is possibly lighter than the stock variator.
The ADVANCEPro drive face has low-profile fins with squared off edges, and at 120mm dia, looked 2~3mm bigger than the stock drive face.
The Daytona variator came with 6x14g rollers, that (in my limited experience) looked to be of very high uniform quality compared to stock.
I chose the Daytona variator and ADVANCEPro 14° drive face based on cost vs availability and high praise from members of this forum.
It was too windy to do any high speed tests today, but my initial opinion of this variator and drive combo on a stock engine is, meh...
Acceleration off the line is slightly less than the stock variator, and maybe similar in the mid range, but feels slower from 70-80kph+.
If adding some 20kph potential top end can only come at the cost of reduced acceleration, then I guess this is how that feels.
I'm uncertain, but let's say that the bike was perhaps a little more relaxed at cruising speed using less RPM to do the same work as before?
I'm somewhat disappointed. However, if I go ahead with performance mods and open up the motor, I feel this setup is a good partner.
I also have a new Daytona reinforced belt and +23% clutch springs to try out. I expect the clutch springs will aid acceleration off the line.
I'm not sure what my next experiment configuration wise with the parts I have will be. I could try 3x11s+3x14r (12.5g) with stock drive face?
I really want as much acceleration to 100kph as I can get. I probably should have tried the MFR variator kit, but I only feedback from 1 source.
Thanks for your attention, Gav.
PS: I scraped something doing a Rossi-style left hander...
![Embarrassed :oops:](./images/smilies/icon_redface.gif)
