New battery
smrbike
New battery
Post by smrbike »
After diagnosing my check engine light problem to needing a new battery, I'm probably getting the OEM replacement GTZ8V 7ah 120 cca apx $55 vs the GSX7L 6ah 85 cca $35. The latter is probably for the rukus. Any feedback appreciated if other options.
Now: '16 PCX150, '13 CB1100
Still-To-Do: Life, ...
Prior: '70s CB450, '90s-00s CB750 Nighthawk
First: '60s Honda 50 or 90
Year: 18 300 xmax
Re: New battery
This is expensive however I always like to have much more reserve capacity and cranking amps (210CCA) than what is called for. Going on two years now, it is 60% lighter/40 % smaller than the OEM battery. Twice the strength. Comes with foam blocks to make the fit perfect.
https://www.amazon.com/gp/product/B005F ... UTF8&psc=1
‘15 PCX build thread here:
Re: New battery
I once bought a cheap replacement for the recommended one. It didn't last very long, so I ended up going back to the recommended one. It is still going. I think the cheap replacement had less CCA.
Limey
Year: 16 Forza/16 PCX
Color: Red/Maroon
Re: New battery
Post by Limey »
I bought this one on Amazon over a year ago. Works great still. never had an issue:
Snap 2019-06-07 at 13.14.49 (Small).jpg (60.93 KiB) Viewed 830 times
smrbike
Re: New battery
Post by smrbike »
Jge64 wrote:This is expensive however I always like to have much more reserve capacity and cranking amps (210CCA) than what is called for. Going on two years now, it is 60% lighter/40 % smaller than the OEM battery. Twice the strength. Comes with foam blocks to make the fit perfect.
Thanks, but Lithium has too many possible fire problems to rest my fears of using one in a car, boat, or 150.
smrbike
Re: New battery
Post by smrbike »
Limey wrote:I bought this one on Amazon over a year ago. Works great still. never had an issue:
That's the 6ah one I mentioned - thanks for the feedback. I realize that it was not as strong as the 7ah OEM or the lithium one another suggested, but for the lower price I felt that i could replace it every 2 years and be ahead of the game a few times over.
Dayvee888
Color: silver
Re: New battery
Post by Dayvee888 »
I put a lithium in my Ducati 996 and it caught fire, lost the bike, even my tears wouldn't put it out.
