Hi everyone.
As a matter of interest to all those riders on the PSX150 with wider tires/tyres, what cold pressure do you all run on front and rear?
Pressure?
- Year: 18 300 xmax
Re: Pressure?
Wider tires shouldn't take any more pressure. It's all about the same ; 29 in the front 33 in the rear
‘15 PCX build thread here:
Re: Pressure?
I actually run lower pressures, 26/28.
- vamootsman
Re: Pressure?
I am running roughly the same as you, about 25 front now and 30 rear as I have my lady friend on the back occasionally (I prefer 28 though). I have City Grip 140/70 rear and 120/70 front. Any more pressure and the rid suffers, and the contact patch is only about an inch wide. Need more rubber on the ground than that.Rain wrote:I actually run lower pressures, 26/28.
2013 PCX 150 with,
2005 Piaggio X9 500 Evolution
1982 Honda CX500 Turbo
1983 Honda Nighthawk S
- vamootsman
Re: Pressure?
They actually take less, more air volume needs less PSI if the bike and rider weight are the same.Jge64 wrote:Wider tires shouldn't take any more pressure. It's all about the same ; 29 in the front 33 in the rear
2013 PCX 150 with,
Re: Pressure?
For me, if the pressure drops too much off 29/33 then I notice the ride suffers, handling is less good.
- vamootsman
Re: Pressure?
What size tires are you running? Stock or oversized?iceman wrote:For me, if the pressure drops too much off 29/33 then I notice the ride suffers, handling is less good.
2013 PCX 150 with,
Re: Pressure?
I noted on my standard sized tires, though they are Michelins, that if the pressure is low on them the handling is much worse. Turning may seem just little harder, and the ride itself is not as comfortable. Sometimes I don't realize that it is the tires at first, but I know that something is not right. It may be the same with oversized tires. Don't be afraid to try different pressures to find the optimal one for your situation.
Re: Pressure?
Stock.vamootsman wrote:What size tires are you running? Stock or oversized?iceman wrote:For me, if the pressure drops too much off 29/33 then I notice the ride suffers, handling is less good.
