Hello brothers
I need a little professional help from the experts here
i have pcx 125 2011 upgraded to full kit 164cc V1 yuminashi
*164cc LIGHT BORE FLAT DECK CYLINDER KIT
*BILLET CNC X250RR 8.6 CAMSHAFT
*31MM PGM-FI THROTTLE BODY SET
*NGKCR10EK NICKEL MULTI-GROUND SPARK PLUG
*31MM MANIFOLD SET
*A-TYPE (6-HOLES) HIGH PERFORMANCE FUEL INJECTOR
*PROGRESSIVE DOUBLE VALVE SPRING & RETAINER
*BIG TUBE AIR INTAKE
*PGM-FI CONTROLLER FOR PCX125 V1
I recently ordered a new upgrade item : 35MM PGM-FITHROTTLE BODY I connected
it to my pcx and the pgm-fi controller Not lighted I do not know why it happened , until now everything worked fine . but Since I replaced the 31MM PGM-FI THROTTLE BODY TO 35MM PGM-FI the pgm-fi controller are don't work and dont turn on , i have swich and all
Can anyone explain to me why this happened?
sorry for my english
THANKS BROS
Connect the PGM FI CONTROLLER to the 35MM throttle Yuminashi
Re: Connect the PGM FI CONTROLLER to the 35MM throttle Yumin
somebody help?
- Year: 2013 PCX150
The two lights on the controller? Set the ign dial back to zero
