i still hate this about my pcx
Posted: Thu Dec 22, 2016 10:12 pm
by eggman
i brought this up b4 but it still drives me nuts .when i check its oil one side of the dip stick shows its overfilled the other side shows it low
Re: i still hate this about my pcx
Posted: Thu Dec 22, 2016 10:27 pm
by Mike888
Same with mine, i think it has to do with the slant of the tube where you put your dip stick. The way I can see is if there is oil on both side then it is ok. But make sure it's not overfilled
Posted: Fri Dec 23, 2016 1:23 am
by chicaboo
Twirl the dipstick anti-clockwise (so as not to tighten it) half to one turn before you withdraw?
Posted: Fri Dec 23, 2016 2:33 am
by alx123
Refer to the side facing the engine maybe?
Posted: Fri Dec 23, 2016 3:44 am
by iceman
Does it matter? As long as the tip and one side to the top marking is wet with oil after a few insertions, cleaning each time, then you can be sure the oil is at an ok level. Only if the tip is dry should you be worried.
Posted: Fri Dec 23, 2016 4:03 am
by eggman
I'm big time ocd about oil level
Posted: Fri Dec 23, 2016 6:01 am
by JetPilot
eggman wrote:I'm big time ocd about oil level
It cant be slanted THAT MUCH.
FIRST: The oil stick should NOT be screwed in to measure the level. Very common mistake... I assume you have this right, but just in case
2. Use a little care and skill, clean the stick before inserting, and you can get a perfect reading, it is NOT slanted enough to cause the kind of error you report. You technique is BAD if you are getting one side low, and the other side overfilled, figure out what you are doing wrong to cause this.
You are correct, oil level is very important. I use great care to make sure mine is always perfect.
Mike
Posted: Fri Dec 23, 2016 10:19 am
by homie
Keep it in the vertical position when viewing, I think once you go horizontal it crawls up the back side. I like the reverse twirl idea... I might try that.
Posted: Fri Dec 23, 2016 1:53 pm
eggman wrote:i brought this up b4 but it still drives me nuts .when i check its oil one side of the dip stick shows its overfilled the other side shows it low
Is there anyone you can speak to about your problem?
Posted: Fri Dec 23, 2016 5:39 pm
by eggman
you you wrote:eggman wrote:i brought this up b4 but it still drives me nuts .when i check its oil one side of the dip stick shows its overfilled the other side shows it low
ha I was hopeing to call you you
Posted: Fri Dec 23, 2016 5:40 pm
by eggman
ty everyone for advice
Posted: Sat Dec 24, 2016 8:18 am
Would be far easier to read if the stick was white.
Posted: Sat Dec 24, 2016 9:56 pm
by fish
Be thankful you have a dipstick.
Suzuki hasn't figured out how to make them. There are a few hundred posts about how to read the Burgman 400 oil windows.
(requires a crew of two, a stop-watch, a mirror on a stick , a monkey and a banana)
(I made up the part about the monkey)
Posted: Mon Dec 26, 2016 3:57 am
There is a very simple solution to the non-problem of the burgman oil window.
Posted: Mon Dec 26, 2016 1:06 pm
^^ on level firm ground raise Burgman on its center stand. perhaps? Could the answer be "that" easy?
Posted: Wed Dec 28, 2016 7:24 am
WhiteNoise wrote:^^ on level firm ground raise Burgman on its center stand. perhaps? Could the answer be "that" easy?
Yes.
Posted: Sat Oct 28, 2017 11:42 am
by WI_Hedgehog
fish wrote:Be thankful you have a dipstick.
OMg that's funny! Do you still need the banana?
