Homie, I don't know what work you have done on your PCX, but anyone who can do what you are doing in the videos certainly deserves to be included in your "Whisper'ers" list. Go ahead, include yourself.
Re: Homie's Garage
Posted: Thu Nov 17, 2016 9:22 pm
by homie
kramnala58 wrote:Homie, I don't know what work you have done on your PCX, but anyone who can do what you are doing in the videos certainly deserves to be included in your "Whisper'ers" list. Go ahead, include yourself.
Yeah... no. This is my first hardcore rebuild of a gasoline motor since small engine class in high school. It's 99 percent service manual and one percent homie, a monkey could do it if he could read. Plus the technology is that of a tractor engine from the 50's. Me thinks not so complicated compared to foreign made bikes. The Honda engine scares me
Re: Homie's Garage
Posted: Thu Nov 17, 2016 9:35 pm
by iceman
Harley's often get slagged off for one reason or another, and I've no idea what other makes are like, but seeing your video and how the engine drops down, wow - they certainly got that right! Nice garage Homie - bigger than some living rooms in London! (actually bigger than many houses in London!!!) Much appreciate all the hard work and sharing of tutorials - great as ever.
Re: Homie's Garage
by homie
American made... much simpler. Shonky as youyou once said
Re: Homie's Garage
Posted: Thu Nov 17, 2016 10:09 pm
by relic
Make sure you have oil pressure before you test drive. Rebuilt my cb350 and cooked the engine because the oil pump had lost it's prime. Most engines have a small threaded port in the head for a gauge or sensor squirt some oil down there and make sure the pump pushes it back out
Really didn't want to learn that by trial and error
Re: Homie's Garage
Posted: Thu Nov 17, 2016 10:57 pm
by homie
relic wrote:Make sure you have oil pressure before you test drive. Rebuilt my cb350 and cooked the engine because the oil pump had lost it's prime. Most engines have a small threaded port in the head for a gauge or sensor squirt some oil down there and make sure the pump pushes it back out
Good point, will run a full diagnostic before start up with ECMspy. Unless I've damaged a sensor somehow, and then even that should report. You peak my curiosity with this oil pressure comment so I might read ahead a little and see if this test is noted of left to the software to find.
Re: Homie's Garage
Posted: Thu Nov 17, 2016 11:02 pm
by relic
That cb350 was before sensors and software I'm just saying that removing the threaded plug can give you the info needed
Your dealing with a relic here!
Re: Homie's Garage
Posted: Thu Nov 17, 2016 11:19 pm
by homie
Here is the thing that keeps me awake at night, perhaps you can advise. Look at my allen wrench set. The ball is missing on one. I snapped it off and searched the area with a magnet but no luck. As fate would have it that tiny steel ball could be down the crank area in the oil. Entirely possible and I must locate it before reassembly. I've thought to drain the oil and use my inspection tool but this seems doubting. I've imagined the oil pump taking up such an object and perhaps sending it to the filter but I have not yet research the pump design or any possible screens that would forever keep it loose in the case. It must be found or I WILL HAVE FEAR!!!! WHERE IS IT!!!!!!!!!!!!!!!!!!!
Never use these new allen wrenches around motors... bad design flaw
Re: Homie's Garage
Posted: Thu Nov 17, 2016 11:38 pm
by relic
if you are lucky the pump has a screen if not -Nightmare!
Should roll out if you drain the oil or find some kind if magnetic drain plug to capture the little devil
Re: Homie's Garage
Posted: Fri Nov 18, 2016 12:53 am
by kramnala58
homie wrote:Here is the thing that keeps me awake at night, perhaps you can advise. Look at my allen wrench set. The ball is missing on one. I snapped it off and searched the area with a magnet but no luck. As fate would have it that tiny steel ball could be down the crank area in the oil. Entirely possible and I must locate it before reassembly. I've thought to drain the oil and use my inspection tool but this seems doubting. I've imagined the oil pump taking up such an object and perhaps sending it to the filter but I have not yet research the pump design or any possible screens that would forever keep it loose in the case. It must be found or I WILL HAVE FEAR!!!! WHERE IS IT!!!!!!!!!!!!!!!!!!!
I feel sick for you. I know the feeling. Sorry for you. Hopefully it works out okay.
Re: Homie's Garage
Posted: Sat Nov 19, 2016 12:41 am
Look at You! Oilee winter project stripping the Buell. Brave. I tip me lid to ya!
Garage lookin' homie get a bed in there and yer set! Some calls it being in a dog house.
That ain't no dog house! That's Puppy Palace!
I see Precious under cover(s) and 'Ol Yella's (Shonky) caged up and feeling nakid. (Is that a cage?)
Did you find that allen wrench ball piece yet? What a nightmare! Devise something!!!! grab that thing, snag that thing, magnetize that thing, Chief says, Go Fish!
Not funny I know. Sorry. Get a stud finder and drag it around. Not that simples.
Let's move away from the missing ball... And onto offing the carbon.
Hmm, after viewing your vids (excellent as always), I wandered away with me popcorn to watch others. The Nasty Nasty Carbon ones! I came across this one, did you see it?
BTW, How's the Weather? Storm coming your way? Crank the heat on for Shonky!
It's a really good idea pivoting the engine as the sportster engines used to be bloody heavy. Might not be now I suppose.
Keep on taking videos as it progresses as it's interesting.
Re: Homie's Garage
Posted: Sat Nov 19, 2016 4:01 pm
by homie
WhiteNoise wrote:(Is that a cage?)
I have to put my Shepard in the cage when it storms He's high strung and turns into a wolf when it thunders, every dog has his glitch. Other than going nuts in a storm he's becoming a pretty good guard dog, and a excellent rodent killer You know how he loves a squirrel. Weather has turned today
I'm confident that stupid tiny broken tool end is not down the crank (magnets and inspection tool). Those allen wrenches are off my owners list. OH! maybe it's laying on top of a lifter be right back.
After reading the SM on oiling system I understand now that gravity feed oil from the reservoir (swing arm on a Buell) moves oil from the swing arm to the pump into the cavity in suspect under the crank. Pressure from the under side of the piston moves oil on through the cooler and then sends it to the filter. From there it off to critical pinions, bearings, valve shafts and top-end stuff. So I think any tiny foreign object dropped into the crank area is on its way to the filter after a short flush through a cooling radiator and might lodge there or for sure in the filter... END!
Re: Homie's Garage
Posted: Sun Nov 20, 2016 2:10 am
by homie
Moving on now with de-glazing. Service manual talks about the importance of a good cross hatch pattern. Apparently the 60 degree (or as close as possible) scoring pattern is needed to initially capture oil evenly on the cylinder walls during run in promoting longer ring and wall life. After de-glazing washing the cylinders with hot soapy water and then oiling them up until installation day... I feel like I've learned something today about seating new pistons & rings.
Re: Homie's Garage
Posted: Tue Nov 22, 2016 12:11 am
by homie
New Piston kits come with bearing, rings and retaining clips. Pretty simple stuff so far for those of you who ever thought to dig into your engine. If this was done right today compression should be factory fresh after break in period, if not... KABOOM!
Re: Homie's Garage
Posted: Tue Nov 22, 2016 9:55 am
by kramnala58
That seems to be a pretty good garage. BTW, are you still making windows? I might be in the market for some in a year or two.
Re: Homie's Garage
Posted: Tue Nov 22, 2016 10:58 am
by homie
kramnala58 wrote:That seems to be a pretty good garage. BTW, are you still making windows? I might be in the market for some in a year or two.
I resize HunterDouglas product for retailers mistakes and window replacement customers that find 20-30k worth of Hunters shades on the floor that are too big. No body tells you that's coming so the smart guy does a search on the the net. Resize, cutdown or alteration + blinds or shades... I'm always at the top of every search engine 20 years running, no competitors. No competitors because the products have evolved into some of the most complicated contraptions that if you don't have the God given gift to take things apart and put them back together right... you buy it
thus I'm confident this engine will run
Re: Homie's Garage
Posted: Tue Nov 22, 2016 3:30 pm
homie wrote:New Piston kits come with bearing, rings and retaining clips. Pretty simple stuff so far for those of you who ever thought to dig into your engine. If this was done right today compression should be factory fresh after break in period, if not... KABOOM!
Can I point out my boxer cup has a similar mileage but isn't considered run in yet?
