Check Engine Light
Posted: Fri Jul 29, 2016 7:27 pm
Hey guys,
I've had my 2015 pcx 150 for a little over a year now and it has given me no problems whatsoever. I changed the oil 3 times and I didn't use it for a couple of days since I was using my car and one day I went to turn it on to go for a ride and the bike won't start. The check engine light is on but it doesn't flash, it's just solid. I misplaced my manual so I can't check what it means and I've googled the problem but have come up short. The stand is up and the idle switch isn't on so it's not usual suspect of the issue so I'm not sure what it is. The oil was changed 2000 miles ago and I see no signs of leaking. Could this be something with the battery? I'm going to take it to a shop but I just wanted to get your opinions first because it might be something easy I'm not thinking of, thank you for your time.
