I know any engine with lots of miles and being abused will burn oil. I just want to know do these scooter burn oil. Even when new or low miles? Looking at buying a PCX or Forza soon.
Thanks in advance.
Are these scooters oil burners?
- honkerman
Re: Are these scooters oil burners?
The first and second oil changes may burn a little oil, just due to break in. There has been conversation about this before; however, I'm on my third change and have seen no oil loss this last time around.
I only check the oil level at oil changes, the level never drops below the minimum.
- honkerman
Right. I've seen small scooters that burn oil, but the PCX doesn't seem to at all.Robert R wrote:Simple answer, No
honkerman wrote:Right. I've seen small scooters that burn oil, but the PCX doesn't seem to at all.Robert R wrote:Simple answer, No
All my two stroke scooters have burned oil. Crazy.
- honkerman
No kidding?you you wrote:honkerman wrote:Right. I've seen small scooters that burn oil, but the PCX doesn't seem to at all.Robert R wrote:Simple answer, No
- Color: red
Mine uses about half the hatched marked area between services
Same here - I did not do the 1st 600 change (hope the dealer did) but did the oil change myself at 5000 and now at approx 7800 it's gone down half the knurled area.Tom192 wrote:Mine uses about half the hatched marked area between services
