I am on verge of purchasing a replacement for my terrible Chinese scooter that finally died.
I have a fixed budget and want a reliable Honda as I will be using the bike on daily commute to work which is a 70km round trip. I am considering the PCX 125 although part of my journey is on a highway with speed limit of 100km/hour and I also have to traverse a mountain pass so wondering if the 125 would be up to it.
I am also considering an XR 125/150 which fall in the same price range. Obviously not a scooter but may be better for the commute.
Feedback/suggestions welcome.
Thanks
Mark
PCX 125 or XR 125
Re: PCX 125 or XR 125
Where are you located Mark? Please fill in all of your information when you get a chance. 100km being 62mph is just about all she has for top speed without a performance kit which would help with climbing a mountain as well but you should consider something other than PCX for your curious location and commuting requirements. Here's a funny video of a guy who stole an XR 125 and then road it all seasons, even gets it to burn out. Then he tears it to pieces for no apperant reason https://www.youtube.com/watch?v=fRJbug0hkLA
"Mountain pass" and "125" perhaps isn't a match made in heaven.
A scooter is better for commuting than a conventional motorbike.
As for "reliable Honda", think again, because there's plenty problems with Hondas.
- honkerman
Despite GN2's cynicism, a true Honda is likely to prove more reliable than something made during the off hours at a Chinese plant with Honda tooling. Tbh though, a 125-150 may be a bit small for your needs. Something above 200cc is more likely to meet your needs. Also, if you'll be doing a lot of altitude changing, a fuel injected machine is best.emjaybee wrote:I am on verge of purchasing a replacement for my terrible Chinese scooter that finally died.
Thanks
Mark
Now, that said, I have a a pcx150 and do a similar type of commute to school every day, hitting 65-68 mph for a short stretch of highway, then jaunting up over a small mountain and around some twisty roads. I'm able to make it work, and I find that the PCX doesn't skip a beat. It can be done, I do it (though the mountains around here may not be like your mountains), primarily to prove it can be done. The fact that the PCX is fuel injected does eliminate any stuttering from altitude changes, though I only run into extreme altitude differences when I travel through the Catskills or Adirondacks, or the Berkshires.
In any event, do what works for you.
- Year: 2012
Hi Mark,
it would be good to know how much your budget for the bike is. I also think that the PCX is probably not the best choice for your commute. It certainly can be done, but I don't think it will be fun for you for a long time. Personally, I don't feel very comfortable riding the PCX around 100 kmh for longer times, especially in strong winds.
Best regards,
Klaus
Best regards,
Klaus
