Re: Fork Stabilizer
Posted: Sat Oct 31, 2015 4:50 pm
OH THANKS! now we have fear boooooooooooooooooo
https://hondapcx.org/
Err, no.davenowherejones wrote:Those 4 bolts at the top of the fork are the only things holding your front wheel to scooter.
davenowherejones wrote:Mario wrote:Fact is that the Forza has a single crown (yoke) design front fork, known for its flex vs double crown designs like the best steering scooter the T-Max, mounting a fork stabilizer is the second best thing you can do on a single crown fork design.
Forza,
Those 4 bolts at the top of the fork are the only things holding your front wheel to scooter. I often wonder why the casting at the top does not crack every time I hit a pot hole. Scary when you look at it.
So is the front fender actually a structural member?
Oyabun wrote:Mario,
Leave it. He's the type of a person who all ways have to correct others to feel he is right. Both of you are saying the same he just does not see the full picture - while literally being correct.
Try taking those four bolts out and see how far you get.gn2 wrote:Err, no.davenowherejones wrote:Those 4 bolts at the top of the fork are the only things holding your front wheel to scooter.
Those four bolts secure the forks in the yoke.
The wheel is retained by the screw thread on the spindle and the spindle clamp bolt.
One of the reasons I said about the four bolts was that mine were not tight and I was having control issues. I have also worked on aircraft where the engine was held in by four bolts. It is critical that they work correctly in both situations.Oyabun wrote:Mario,
Actually, I have fear every time I ride. Girls texting, truck drivers dumping their loads, RCMP hiding in the bushes, gang members shooting each other, senile senior citizens with dementia, drunk drivers, mountains falling down, rivers and snow.homie wrote:OH THANKS! now we have fear boooooooooooooooooo
In honour of the recent Back to the Future Day I took my Forza up to 88 mph. I am too old to go that fast but I did it once and then slowed down. I like my Forza but it sure is not a racing bike. ps Nothing happened at 88.homie wrote:I was hoping I didn't read this whole thread for nothing.iceman wrote: If someone brought out a flux-capacitor for the PCX I bet there are some that would by it hoping to warp time and space, only it would be hard to reach the 88mph to activate the device!
You'll go a lot further than if you took the wheel spindle outdavenowherejones wrote:
BRed wrote:I think that's the deciding factor here.....speed!
If you've ever ridden your Forza in a full tuck at 85mph (or faster) and leaned on the handlebars for a fast lane change, you've probably had to oversteer and then correct because of the springy front end Mario mentioned.
You don't notice it at lower speeds but over 80mph there is a little steering lag....
I think the gyroscopically stabilized front wheel resists input a little more at those higher speeds.
and yes, the fender IS a structural member, since it's the closest thing to a fork brace you get!
on the fork brace...
for those who ride like Mario, it's a good idea...
for those who putt putt at 45, not so much.
I can't say I've noticed a huge handling problem - PCX main weaknesses are 1. Low ground clearance getting over a bump at the end of my road (to be solved later with bigger shocks hopefully) and 2. It's a scooter - the engine is bouncing along with the back wheel. It's choppy, get used to it!gn2 wrote:It won't, tis but a cosmetic foible.Mel46 wrote:Let us know if it makes any difference.
