I like these valve caps http://bikerzbits.com/tyre-valve-cap-bikers-cnc.html but I think the may be a little heavy so I think a wheel balancing may be necessary.
Opinions?
Bikers Valve Caps; wheel balancing necessary?
Re: Bikers Valve Caps; wheel balancing necessary?
Bin them and get plastic ones.
Plastic ones will never fuse onto the valve stems.
Will your wheels need balancing because of these caps?
Absolutely not.
Absolutely not.
- Year: 2015 Forza 300
Lubing valve thread a little avoid fusinggn2 wrote:Bin them and get plastic ones.
Absolutely not.
kar120c wrote:Lubing valve thread a little avoid fusinggn2 wrote:Bin them and get plastic ones.
Absolutely not.
gn2 wouldn't be wasting any lube on his valve stem.
KY is expensive, mind you sometimes Vaseline can be had at a baaaaaargain price.
Lube is for poofs.you you wrote:gn2 wouldn't be wasting any lube on his valve stem.
gn2 wrote:Lube is for poofs.you you wrote:gn2 wouldn't be wasting any lube on his valve stem.
Slight whiff of hand cream drifts slowly by....
