Honda Forza 125 Specifications
Posted: Tue Apr 21, 2015 12:44 pm
2015 Honda Forza Specifications (mirrored here from Honda's Website)
ENGINE
Engine Type Liquid-cooled 4-stroke 4-Valve SOHC single
Bore And Stroke 52.4mm x 57.9mm
Compression Ratio 11.5:1
PGM-FI electronic fuel injection
Max. Power Output 10.5kW @ 8,750rpm
Max. Torque 12Nm @ 8,250rpm
DRIVE TRAIN
Transmission Honda V-Matic continuously variable automatic transmission
CHASSIS / SUSPENSION / BRAKES
Front Suspension Telescopic
Rear Suspension Twin shock
Front Tire 120/70-15
Rear Tire 140/70-14
Antilock Brake System
DIMENSIONS
Dimensions (L×W×H) (mm) 2,134 x 748 x 1,452
Frame type Tubular steel underbone
Fuel Capacity (Litres) 11.5
Fuel Consumption 123 mpgl (WMTC)
Ground Clearance (mm) 148
Dry Weight (kg) 162
Seat Height (mm) 780
Wheelbase (mm) 1490
OTHER
Available Colors: Moondust Silver Metallic & Matt Cygnos Grey Metallic / Matt Cool White & Matt Pearl Pacific Blue / Black & Pearl Havana Brown
MSRP £3999
ENGINE
DRIVE TRAIN
Rear Tire 140/70-14
DIMENSIONS
Dry Weight (kg) 162
Wheelbase (mm) 1490
OTHER
MSRP £3999
