No experience with there variator a in the slightest, all I know is they cost a fair bit.
Having looked around the Internet people are claiming seeing 70+ mph from installing one can anybody confirm this on here?
Multivar2000
- danieljw
- Color: RED
Multivar2000
Honda PCX125 - 1000miles
Re: Multivar2000
Not sure if they do a 2015 version yet but the multivar i have in my 2012 gives me an "indicated" top speed(brand new belt) of 84mph on the stand, 80mph on the road(slight downhill no headwind) after 2k on the belt its now topping at 76 mph. I have a ermax+25 windsheild, without that i'd knock at least 5mph off. Acceleration is also improved in a big way.
Honda forza 125 2019
Yellow malossi contra spring
Malossi delta clutch and bell
Malossi special kevlar belt
K and n air filter
Akrapovic exhaust
Malossi White Contra Spring
Malossi yellow clutch springs
Daytona reinforced belt
DNA Performance air filter
Removed air box flange
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
- danieljw
- Color: RED
Re: Multivar2000
the 2012 one should fir the newer 2015, same engine as the 2012 is ESP, therefor its giving nearly 10mph extra with only a screen added?
Re: Multivar2000
The screen Definitely helps my large frame get to a higher top speed, best 2 performance mods ive done is multivar and windsheild.danieljw wrote:the 2012 one should fir the newer 2015, same engine as the 2012 is ESP, therefor its giving nearly 10mph extra with only a screen added?
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
- Year: 125 cc MY2015
- Color: red
Re: Multivar2000
I have 2015 125cc version with multivar and Givi windshield.
My speed on the stand is 130kmh(81mph)@9600 rpm, on the road 112kph(70mph)@9000 rpm.
I cannot redline on the road.
As buddy1976 said windshield is a great improvement, I gained about 10 kmh and 600/700 rpm.
- Color: red
Re: Multivar2000
D1136ST model.danieljw wrote:which give windshield do you use?
As Givi told me, it will be the only one for 2015 PCX (no taller version).
Ciao
