installing new, big Honda wind screen on your Forza
This fellow has very helpful instuctions for removing the panel to fit the bigger Honda screen on your forza.
http://myforza300.wordpress.com/2013/09 ... 0/#more-18
SECoda
Honda Forza 300 &
Honda Forza 300 &
Re: installing new, big Honda wind screen on your Forza
Post by SECoda »
Cool. Thanks. I picked up the Givi Tall but that will do.
Vesper2112
Year: 2014 Forza
Post by Vesper2112 »
That's exactly the site I went to when putting my Givi tall on. Wish he'd do more updates.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
I don't think I spent more than 30 minutes putting the Givi on my PCX. Is the Forza a bit more difficult?
SECoda wrote:I don't think I spent more than 30 minutes putting the Givi on my PCX. Is the Forza a bit more difficult?
It is a real tug to get these yellow plugs out of the holes they are clipped into.
Loosen the bottom, then pull out a little and down.
The 2 yellow plugs clip into these holes...one on each side Image
I buttered them up with silicone grease for next time!
Probably not a good idea to try this if the plastic is cold.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
Ah! I see. Thanks. There is probably nothing in the service manual on this.
SECoda wrote:Ah! I see. Thanks. There is probably nothing in the service manual on this.
The manual has a microscopic drawing of arrows, lines and a thing that could be a tab and a hole it goes in.....over there....
This is page one, step one for taking the whole scooter apart...."Remove.... by releasing the following....."
The "releasing" is the magic part.
This is why BRed's exploded scooter pix are so impressive to me! He "released" practically everydamthing! Just for the heck-of-it!
An AMAZING feat of daring!
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
I just suffered through this again. For future folks the problem is the red tab on the bottom front that the bolt goes through has a larger hole so that the black bottom piece protrudes up into that hole where the bottom bolt goes up. You must release the red tab off of the black nub sticking up through the hole. You can't just pull it out or you may break the tab off. You must come at it from the back and pry the red tab up. Then it falls out.
The side tabs are minor compared to that.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
Little Givi and Big Givi.
