Headlight Aim Vertical Adjustment 2015 PCX
Posted: Tue Oct 28, 2014 2:51 pm
Given that some 2015 users in the States and in Spain have trouble locating the Headlight Aim Vertical Adjustment screw, I have taken some pics to try to show its location:
Once you have located the screw, it's a 20 second job
You can use a Philips screwdriver, or a regular 10mm wrench
You simply have to turn the screw:
* Clockwise: The beam goes down
* Counterclockwise: The beam goes up
No need to do anything else. When the beam has reached the desired length/reach, you simply stop rotating the nut, and it's done One can easily do it on route, as is extremely simple and fast.
I use this special 10mm wrench:
