Headlight Aim Vertical Adjustment 2015 PCX
pcxpower
Post by pcxpower »
Given that some 2015 users in the States and in Spain have trouble locating the Headlight Aim Vertical Adjustment screw, I have taken some pics to try to show its location:
Once you have located the screw, it's a 20 second job :D :D :D :D
You can use a Philips screwdriver, or a regular 10mm wrench
You simply have to turn the screw:
* Clockwise: The beam goes down
* Counterclockwise: The beam goes up
No need to do anything else. When the beam has reached the desired length/reach, you simply stop rotating the nut, and it's done 8) One can easily do it on route, as is extremely simple and fast.
I use this special 10mm wrench:
2015 Honda PCX 125
Re: Headlight Aim Vertical Adjustment 2015 PCX
Bump
For member Ishkabibble and others that want to know how to adjust their headlight beam.
Our thanks go to member pcxpower
User TIP: Remember you can bookmark threads of interest (sign in as a member first) so that you can refer to them anytime you want. Just click the bookmark tab at the top of any thread's page to save it, then Go to the user control panel and find it under manage bookmarks. Simple :P
pcxpower
Post by pcxpower »
Thanks for the bump to help users adjust their headlights! ;)
2015 Honda PCX 125
