Ignition key difficulties
Is anyone finding difficulties with their ignition key sticking in the barrel?
Mine has happened a couple of times and the key seems to be jammed and only by a little gentle manipulation will it move forward or backwards.
Other than a spray of wd40 I really can't think of any solution for it
Re: Ignition key difficulties
You could use wd40 but it can collect dirt and make it worse. Locksmiths recommend a dry graphite powder. A spray is available in maplin.
It's best not to be too liberal with it though as it might get into the electrical part if the switch.
If it's a forsa you have gn2 was saying his was sticking as well. Maybe there's a issue with them.
Mine has occasionally been stiff but wd40 fixed it.
This or this or this should work. Put a bit "on the key" itself and insert several times (keep paper towel handy)
http://www.amazon.com/Panef-Corp-Powder ... 959W5N7Q0Z
http://www.amazon.com/Master-Lock-2300D ... =lock+ease
http://www.amazon.com/American-Grease-S ... =lock+ease
Pfft gumph frrrt hehegn2 wrote:Mine has occasionally been stiff but wd40 fixed it.
- willajabir
you you wrote:Pfft gumph frrrt hehegn2 wrote:Mine has occasionally been stiff but wd40 fixed it.
I wanted to say something first, but I was laughing so hard at what I wanted to say, I had tears in my eyes!!!!!!!!!
Larry
2014 NSS300E born on 12/11/13
May the Forza be with you
It gets stiff quite regularly, when wd40 doesn't do the trick my wife fixes it for me.
She knows all kinds of tricks to take the stiffness away.
Mine would sometimes stick to the first position (fuel door/seat) when turning it. I tried oiling the lock cylinder but what really worked was to use a wire wheel machine at work to de-burr the key.
10-20 seconds was all it needed.
Current - 2015 Honda CBR650F
The new 2014 PCX has new keys (according to the deaker) - not sure what the difference is or what the original looked like.
look to the obvious. I missed that one. Easy fix.Slickvic wrote:Mine would sometimes stick to the first position (fuel door/seat) when turning it. I tried oiling the lock cylinder but what really worked was to use a wire wheel machine at work to de-burr the key.
Got some of the powder and it works a treat - thanks for the link!WhiteNoise wrote:This or this or this should work. Put a bit "on the key" itself and insert several times (keep paper towel handy)
