sendler2112 wrote:
If anything, these bikes are prone to chatter on accel from a stop due to the front pulley opening up too wide and losing contact with the belt. There is no more low gear to be had by adding any spacers.
Milling the boss after installing sliders will increase top gear by pushing the belt all the way out onto the previously unused portion of the variator face. And prevent the chatter on take off. But it will start to make a slight misalignment.
This is good.
By my calcs, I only need to move the belt out 2mm meaning I need to shorten the boss by 2 x 2sin(15°) ≈ 1mm.
Is it worth stressing about 1mm misalignment?
Mgalutia88 wrote:Wingz, have you priced a takegawa aviator and reinforced belt from webike? It would be cheaper than a gear kit..
I looked and agree it is not expensive. I also wonder if the reinforced belt is lower profile - that would give more gear range.
The shortened boss would achieve the required increase in gearing without costing a cent and then there is no shipping hassle to deal with.
I'm still waiting for my sliders by the way.
To my mind, a gear kit would be the next mod if maxing the gearing through variator/boss mods is insufficient.
Mgalutia88 wrote:Also the pcx esp models use a 13/44 gear set as opposed to the pcx v1 13/53. That's a 20.4% change in gearing. You can get the factory gears for cheap. Roughly the same cost as the kitaco kit.
Not according to you...
Mgalutia88 wrote:Ok so Kitaco DID tell me that their high gear kit does not fit the pcx 150, however, according to the honda parts schematics it should!!! Kitaco and Yuminashi went about replacing different gears. Kitaco replaces gear number 07 in the diagram, while yuminashi goes about the change by replacing both gears 06 & 08.
Pcx v1
http://www.advantagepowersports.com/fic ... veh=190428
Pcx esp models
http://www.advantagepowersports.com/fic ... veh=135098
The gears 05&07 are identical tooth count for all pcx models however gear 05 is a different p/n. Gears 06&08 however are the same on pcx 125esp and 150esp models but different on the 2011 pcx.
They are 13/47 on the v1 pcx while 13/44 on pcx esp models.
All this being said, with gear 07 being the same p/n and the gear Kitaco replaces it should be compatible and I wonder what would happen if you replaced both? What could you possibly do?
waspmike wrote:Mgalutia88 wrote: Also the pcx esp models use a 13/44 gear set as opposed to the pcx v1 13/53. That's a 20.4% change in gearing.
It's late here and I'm 4 beers ahead but I got 16.9% am I doing it wrong?
You mean -16.9%? But the quoted figures are wrong anyway.
Anyway, the pcx v1 is provides lower gearing. That is, 44/47 = 0.936 of the esp gearbox in other words -6.38%.
Would be nice to do that mod in reverse (for those with PCX v1 scooters).
