It doesn't have to.sendler2112 wrote:Good equipment costs a fortune.
You can get riding gear which will withstand a Scottish winter for a few hundred quid.
Agree. 30 minutes or more at sub 3C temps and 55 mph will have you stopping to warm your fingers on the engine regardless of whatever clumsy winter ski gloves you are wearing as I did two years ago before getting my heated gear. This is basically less than safe to ride with your fingers so stiff. My heated glove liners allow me to ride any distance in cold temps as long as there is no danger of ice.Cracksta wrote:On all the bikes I've commuted with, the main issue in winter riding is your hands freezing and if frozen, you hands hurt and cannot operate the controls quick enough!
ohhh, the thought riding in sub zero temperatures...and they laughed when i moved from the UK to Thailand...sendler2112 wrote:Agree. 30 minutes or more at sub 3C temps and 55 mph will have you stopping to warm your fingers on the engine regardless of whatever clumsy winter ski gloves you are wearing as I did two years ago before getting my heated gear. This is basically less than safe to ride with your fingers so stiff. My heated glove liners allow me to ride any distance in cold temps as long as there is no danger of ice.Cracksta wrote:On all the bikes I've commuted with, the main issue in winter riding is your hands freezing and if frozen, you hands hurt and cannot operate the controls quick enough!
gn2 wrote:It doesn't have to.sendler2112 wrote:Good equipment costs a fortune.
No problem at all, up here we just ride in the bare scuddy when it gets too hot.you you wrote:But could it cope with a Scottish summer?
In the warm rain?gn2 wrote:No problem at all, up here we just ride in the bare scuddy when it gets too hot.you you wrote:But could it cope with a Scottish summer?
15 degrees. That's summer for us. What a wimpLee.R wrote:I've been doing this for a while now. I'm from Maine and moved south to Maryland a few years ago. From my observations about commuting in the cold.
Get heated gear if your going below 50 degrees for any long period of time. You can make short hops and not be very cold but a heated jacket will make it actually enjoyable. You have to keep your core warm or your hands and feet start to get cold as your body is attempting to survive by conserving heat. You can't fix this with just heated grips or insulation, only slow it down. Over time cold always wins and your hands and feet will go numb. Just get a heated jacket trust me on this it's the single most important article for cold weather. I don't even use insulated gloves until the temps are below 35 degrees (I do have hand guards to block the wind) With the core warm, hands and feet will be toasty. I was stubborn about this but a 12 hour ride over 700 miles where I encountered rain at 35 degrees which soaked through my aerostich changed my mind.
Next most valuable peice of gear is a quality neck gaiter that is wind blocking, nothing is worse than air anywhere on your neck of face below freezing, nevermind you'll get frostbike extremely fast at 55mph below freezing with exposed skin. I use one that wraps up around my head and over the cheeks under my helmet. I usually keep the visor cracked for prevention of frost formation. Ice fog is a bitch though, you'll need a heated visor if you want to tackle that.
Layer up with some good windbreaking clothing, I usually commute with a aerostich one peice with normal cloths underneath, khaki's/jeans and collared shirt with just the heated jacket keeping me warm. I don't even wear insulated socks or boots. This is for a one hour commute btw.
The rest is just good quality normal gear, the heated stuff is a game changer. You can go out all day in freezing temps and actually enjoy yourself.
I don't know what scooter's output for spare wattage but a heated jacket is about 95 watts on high, they may be able to power it without issue, a volt meter can be used to test that. I use a small voltage meter on the bike to prevent a dead battery. Your stator will be fine as they run 100% all the time with excess running to ground via the regulator/rectifier. I've read people stating you will burn out your stator with heated gear, you won't you'll just have a dead battery and possibly stall if the voltage get's too low for the FI to run.
As for the bike itself? I ride more carefully in the cold, tires take a lot longer to warm or don't ever get to operating temps so they will not have as much traction, this goes for all of them. You'll hit ice eventually as some melt/runoff from somewhere will cross the road, level up and go neutral on everything and coast over it. Don't turn, brake or gas or you're going down. Because of this always give yourself an "out" for cornering as you may need to go strait to get over a patch of ice. You'll need to be extremely alert. If your not capable of that kind of vigilance that don't go out below freezing.
Keep in mind bridges freeze faster than the road, metal is slippery, wet wooden bridges are really slippery (my only crash on the street in 15 years, green algae on it).
You'll deal with salt, ACF-50 is amazing, coat your metal parts other than brakes and tires (common sense) and it'll look like new in the spring when you wash off the grime. It also prevents the electrics from corrosion, it's made for aircraft.
Be aware that other driver's don't expect to see a bike in the winter (usa) and you'll need to be VERY cautious about motion camouflage and predicting there not seeing you, you have to be extra careful in the off season. I wear hi-viz and have LED auxiliary lights running to help with this. Take some rider's courses if your new and think ahead and predict your surroundings.
Finally prepare to have co-workers think your mental when you show up day after day and it's 15 degrees outside.
33C this Sunday in Gibraltar - I wanna go back!sendler2112 wrote:34F/ 1.5C this morning and still toasty.
You have Gibraltar, I'll have Spain. Vamanos!!djcat wrote:33C this Sunday in Gibraltar - I wanna go back!sendler2112 wrote:34F/ 1.5C this morning and still toasty.
