My 2013 PCX 150 feels like it is sitting too low in the rear. What specific shocks or length of shock should I be looking for for replacing the stock ones that are on it.?
Does any know a measurement I can take to see if it is actually sitting low? I seem to scrape the underside quite a bit on bumps and in tight leans.
Specific rear shock recommendation
Re: Specific rear shock recommendation
I'm new here and have read many post regarding the rear shocks. To begin with they are junk. We can tell that by the replacement cost from Honda. I'm interested in lowering the rear of my PCX and people here were recommending Takegawa 280mm shocks to lower it an inch. I only bring this up because Takegawa might have a larger shock that will cure your problem. I hate to ask but how much do you weigh?
