2015 PCX Won’t start - need ideas
Mckinnonw
Post by Mckinnonw »
I am getting my 2015 PCX 150 up and running for the season. It sat over the winter. When I tried to crank it this morning the battery was dead. I pulled the battery and charged it using a battery charger that I have. The battery shows fully charged. Now when I turn it on the lights go on and the speedometer goes through the normal start cycle, but the check engine light is on and it will not start. Here are my questions…
Is it possible that the battery being changed requires me to reset some thing on the engine to the check engine light goes out?
Is there anything else you need to do when you get a new battery?
Is there a way to get a diagnostic code on the check engine light?
Thanks everyone!
By the way, kickstand was up brake lever was pulled in and Killswitch was on. It should’ve started. I have two of these and got the other one started and running pretty quickly.
DAB
Re: 2015 PCX Won’t start - need ideas
Post by DAB »
When you say "it won't start" is that it won't crank over or won't fire up?
Other rides
Mckinnonw
Post by Mckinnonw »
It won’t even crank. Total silence when you press the start button. No clicking, nothing…
DAB
Post by DAB »
You need a new battery.
Other rides
dankly1
Post by dankly1 »
I think Dab is probably right. The cold can kill a battery when it's left sitting. Did you have a battery tender on it over the winter?
If you want to make sure before you buy a new one, you could take it to an auto parts store and have them do a load test on it. Good luck
Dankly
2019 PCX150
2013 Yamaha FJR1300
1983 Suzuki FA50
Iron Butt Association #80052
The most common problem with the PCX is a dead battery. Look for a new battery with high cold cranking amps.
