Any online site to purchase cheap OEM spare parts for Forza 300?
150pcxer
Post by 150pcxer »
Any online sites which you guys usually use?
Any Thailand-based ones?
Thank you.
davenowherejones
Re: Any online site to purchase cheap OEM spare parts for Forza 300?
Post by davenowherejones »
I need a muffler joint gasket and a front brake rotor. Also rear brake pads. An air filter would be good also.
I have 100,000 miles on my bent front wheel so why replace it.
A spare belt would be wise.
canthai
Post by canthai »
150pcxer wrote: Sun Jan 16, 2022 11:47 am Any online sites which you guys usually use?
Thank you.
https://bikerzbits.co.th/honda/forza/
The Honda dealer sells for a little bit less, but I know of no other choice for overseas purchase of OEM parts at these prices
glencoeman
Post by glencoeman »
EBC do brake rotors for front and rear, as well as brake pads. The muffler joint gasket is an expensive one available From Honda - I haven't see after market ones for sale. A pattern air filter may be available from HiFlo, although not listed as such, it appears to be the same as the Honda SH300, which is listed.
canthai
Post by canthai »
davenowherejones wrote: Sun Jan 16, 2022 3:16 pm I need a muffler joint gasket
If a flat gasket, buy some gasket paper - thick - from anywhere and coat both sides with red silicone
glencoeman
It's not a standard gasket. It's round and quite thick - a special Honda part Number: 18391-MN1-670. Price in UK is £12-13. It's called a Packing Muffler by Honda.
150pcxer
Post by 150pcxer »
canthai wrote: Sun Jan 16, 2022 7:07 pm
Thank you.
I'm aware of bikerzbits, since I use it predominantly to find parts for my pcx. Its range for pcx parts is almost 100%. As for how extensive It stocks parts for the forza, not sure.
I want to find if there are any online sites which sell parts for the Forza, like extensively; engine parts, frame parts etc. Since availability of cheap spare parts is a key consideration for me before I buy the forza.
