Hello, I purchased a 2016 PCX with less then 1000 miles on it. The question I have is on the vent tube on the transmission one of the previous owners removed the transmission breather tube and put a tiny K&N filter at the end. I see the breather tube on the parts schematic and was wondering did it attach to anything?
Also they removed the airbox and installed a K&N filter on the air cleaner connector tube. I will be putting it back to stock.
I had a 2010 Honda SH150 for a number of years so a lot of items look familiar to me.
I'm in the process of changing out all the fluids and checking the valves for the first time. The SH was very easy to do a valve check but this bike is more modern with the LED lights and 28 liter under seat storage so I'm willing to spend the extra time.
Thanks for any information.
Transmission vent question
- Color: Grey
1978 Yamaha 750E (Good Memories), 1996 Honda ST1100 ABS/TCS (Sold), 2004 Yamaha FJR1300 (Sold), 2010 Honda SH150 Urban Assault Vehicle!(Sold,sniff), 2012 Suzuki DL650 (Sold), 2018 Kawasaki KLX250 (Sold), 2016 Suzuki Burgman 400 (Main Ride!) 1999 BMW R1100RT (New to me) 2016 CBX150 (Road Warrior)
- Year: 2018
Re: Transmission vent question
If you're referring to the clear approx 3/8" diameter tubes that extend toward the rear, the originals were pinched at the end to allow pressure out but prevent inflow - acting like a PCV valve or kazoo of sort . You could probably get replacements cheap somewhere, just a short clear tube pinched at the end.
- Color: Grey
A couple of pictures to show what I'm dealing with.
- K&N air filter instead of airbox
- 20210721_080455_resized.jpg (264.17 KiB) Viewed 823 times
- Transmission vent tube
- 20210721_080448_resized.jpg (110.04 KiB) Viewed 823 times
- Color: Grey
No it wasn't that part. That is built into the air cleaner housing. This is a vent coming out of the top of transmission case.springer1 wrote: ↑Wed Jul 21, 2021 10:31 am If you're referring to the clear approx 3/8" diameter tubes that extend toward the rear, the originals were pinched at the end to allow pressure out but prevent inflow - acting like a PCV valve or kazoo of sort . You could probably get replacements cheap somewhere, just a short clear tube pinched at the end.
- power-full
- Year: 2010
- Color: preta
there are some parts missing .. as for the rear wheel , the tube comes out and connects to the air filter box . is the number 2 in the photo where the box reels are
- Screenshot_2021-07-25-09-02-18-868.jpg (68.9 KiB) Viewed 794 times
- Screenshot_2021-07-25-09-02-58-332.jpg (65.64 KiB) Viewed 794 times
- Color: Grey
Thank You! I got a used airbox on Ebay so I'll put it back to stock.power-full wrote: ↑Sun Jul 25, 2021 3:05 am there are some parts missing .. as for the rear wheel , the tube comes out and connects to the air filter box . is the number 2 in the photo where the box reels are
