2019 Honda PCX 150 Tire Pressure
- SantinoInc
- Color: Gray
Ok, so the manual calls for 29PSI for the front and 36PSI for the rear. The odd thing is that every tire gauge I use says thst the PSI is well below those figures and the tires are already very firm. Am I missing something here? Are the tires supposed to be very firm and rigid with no give?
Someone please help me out here
- Year: 18 300 xmax
Re: 2019 Honda PCX 150 Tire Pressure
29/33......
‘15 PCX build thread here:
- SantinoInc
- Color: Gray
- Year: 2018
Yes. But you might want to get a 2nd gauge and verify the PSI. They are cheap enough. Use the recommended pressure or something close to it.SantinoInc wrote: ↑Fri Apr 16, 2021 7:42 pmShould the tires feel very firm at that those PSI? Like you can't even pushed them in at all?
- SantinoInc
- Color: Gray
Thanks for the advice, I'm going to buy a third gauge to be sure I have the pressure right!springer1 wrote: ↑Fri Apr 16, 2021 8:34 pmYes. But you might want to get a 2nd gauge and verify the PSI. They are cheap enough. Use the recommended pressure or something close to it.SantinoInc wrote: ↑Fri Apr 16, 2021 7:42 pmShould the tires feel very firm at that those PSI? Like you can't even pushed them in at all?
- raito
- Color: matte silver
Get a TPMS. It is not as cheap as a simple gauge, but it can tell temperatures too, so you know what PSI to expect at what temperature as you ride. I try to only look at it before going out and on my way home at the end of the day. It is a convenience. It has allowed me to detect a nail in my tyre early, and also when my repair plug started failing.
- Readings when I arrived home just past sunset
- IMG_20210206_184147.jpg (26.69 KiB) Viewed 9482 times
- SantinoInc
- Color: Gray
What particular brand do you have on yours? How much did it cost you?raito wrote: ↑Sat Apr 17, 2021 10:55 am Get a TPMS. It is not as cheap as a simple gauge, but it can tell temperatures too, so you know what PSI to expect at what temperature as you ride. I try to only look at it before going out and on my way home at the end of the day. It is a convenience. It has allowed me to detect a nail in my tyre early, and also when my repair plug started failing.
- Year: 18 300 xmax
If you’re going to come on and discuss a product please put a link. Here’s the one that I’ve been using for the past three years , it’s been flawless.
https://www.amazon.com/gp/product/B076D ... UTF8&psc=1
- raito
I got a Chinese unbranded reseller product: https://www.aliexpress.com/item/4000528793184.htmlSantinoInc wrote: ↑Sun Apr 18, 2021 7:26 pm What particular brand do you have on yours? How much did it cost you?
I paid US$28.89 for it.
Been using it since early February, so only just over 2 months but so far I am very satisfied. I ride almost every day, I just got lazy checking the tyre pressure before every ride the old way.
- SantinoInc
- Color: Gray
Thank you for the added efffort...it's much appreciated bro!raito wrote: ↑Sun Apr 18, 2021 9:22 pmI got a Chinese unbranded reseller product: https://www.aliexpress.com/item/4000528793184.htmlSantinoInc wrote: ↑Sun Apr 18, 2021 7:26 pm What particular brand do you have on yours? How much did it cost you?
- Color: silver
To jge64: the one you showed a link to, on Amazon, was it easy to set up? I tried getting one once but found the instructions indecipherable. How does the monitor attach to the scooter to show the pressure read outs? Thanks.
U.S. Army retired
Former MSF Instructor
Fully retired!
2019 Honda PCX150
2021 Can Am Spyder RT
Fully retired!
2019 Honda PCX150
