Just a heads up if you use stock parts. The 2015 moveable drive is compatible with the 2013 [same boss for both years]
Big price difference. The 2013 piece is $70.00 something. The 2015, about $15.00. A bit cheaper at Partzilla [about $60.00]
The 2015 outer drive immoveable is only about $5.00. Ridiculous but?? Forget about buying stock headlight bulb $70 something!
[each] Already have those parts on my PCX, just to confirm.
2013 PCX moveable drive
- Limey
- Year: 16 Forza/16 PCX
- Color: Red/Maroon
Re: 2013 PCX moveable drive
What is a moveable drive??
I'd imagine he means the variator
Sent from my SM-G930F using Tapatalk
For $70 you are better off going aftermarket. NCY variator is under $70. Much better than stock.
2017 PCX 150
Wirus Win Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Wirus Win Exhaust
Z-Bars
NCY Variator
Agree..........might have gone that route. However, the 2015 part was only $15.00 [inner & outer about $20.00 together] Hard for
this bargain seeker to pass up. Know the NCY increases the speed,substantially......but, rarely ride near those speeds. Pretty much
just back roads. Interstates etc, not for me.
mymitzi, I don't ride on freeways either but the NCY variator has helped greatly when riding back country roads, especially on hills. It is just nice to have the extra power to use when needed. Of course, you may not have the hills that we do, in which case you will not need extra power. However, it may not be something every rider will need or want.
Still, it is like buying a car with enough power to get up hills when needed. It is just nice to know that it is there in case you need it.
Thanks Mel.....The deed is done.....Had the 2015 parts not been compatible, probably would have gone NCY route. Maybe ,next time??
