Probably dumb headlight move
Posted: Wed Aug 12, 2020 6:30 pm
by MBMyer
At just over 12,500 miles, my left low beam burned out. This evening I made the probably stupid move of installing a pair of Osram Nightbreaker 60/55w bulbs instead of the stock 35/35w bulbs.
I’ll let you all know when this experiment fails horribly and destroys my electrical system.
Pax et bonum,
Michael
Re: Probably dumb headlight move
Posted: Wed Aug 12, 2020 7:15 pm
by mymitzi
Hopefully, the fuse saves you.
Posted: Wed Aug 12, 2020 7:24 pm
by fish
Will those run significantly warmer than the stock bulbs?
Never had a night riding problem with my Forza....and I rode in the dark nearly every day.
Good luck...
Posted: Wed Aug 12, 2020 9:14 pm
by davenowherejones
I tried the hotter bulbs but they did not last very long.
It was a problem changing them so I replaced both bulbs with LED equivalents. The LED are probably not in the exact right place. I hardly ever ride at night so it is not a big problem.
I also added some light weight LED flood lights to the side of the plastics by the factory headlights. The LED floods are just barely bright enough to be slightly annoying. They add almost nothing for my night riding. They are basically marker lights.
Posted: Thu Aug 13, 2020 5:39 pm
fish wrote: Never had a night riding problem with my Forza....and I rode in the dark nearly every day.
Presumably night.
