Topbox instead of pillion seat?
Posted: Sat Jun 20, 2020 4:25 pm
by Hassan
Hi All, I currently own a PCX 125 2020, and bought it blind and didn't consider the pillion seat to be so big compared to a 50cc bike. Instead of adding a topbox on to the body and making the body length longer, I was thinking of adding a topbox to the pillion seat but haven't found any online. Is this possible? and if you have seen any online could you link them, please. I'm in the UK.
Re: Topbox instead of pillion seat?
Posted: Sat Jun 20, 2020 5:31 pm
by RuffStuff
Food delivery racks sit half over the rear seat, check ebay
Sent from my SM-G930F using Tapatalk
Posted: Sat Jun 20, 2020 10:22 pm
by Gil
RuffStuff wrote:Food delivery racks sit half over the rear seat, check ebay
They do, the ones I have seen use two pieces of plywood with a piano hinge. That way you can just lift the box when you need to access the under seat storage.
Posted: Sun Jun 21, 2020 2:45 pm
by RuffStuff
Gil wrote:RuffStuff wrote:Food delivery racks sit half over the rear seat, check ebay
Also metal ones about that work on a similar idea, any small engineering place could knock one up tbf.
Posted: Sun Jun 21, 2020 2:54 pm
by RuffStuff
Posted: Sun Jun 21, 2020 9:39 pm
by MikeP
How about a BBQ instead of a pillion seat?
My latest project for my day trips. Finally perfected the mounting board, in the process of finishing it.
Posted: Thu Jun 25, 2020 6:01 pm
by dgnyberg
I didn't like the look of the rack and box sitting out in mid air behind the scoot. So, I use two straps to hold my top box to the pillion. I cut two sliced on the seat base and run the strap through those holes to keep the box from moving around. It's not permanent and the box becomes a back rest for me. When I raise the seat, the top box goes up with it.
Posted: Thu Jun 25, 2020 8:36 pm
