Suggestions for the best way to tie down a load
Brice
Post by Brice »
Somewhere on this fantastic forum I thought someone suggested the best method for securing larger objects on the back.
Can I be directed to that or a have refresher posted?
I'm getting a 25 lb of birdseed. Working from home means I needs to improve the view in my backyard. And I don't care how cheap gas prices get its always a better ride on a PCX than a minivan.
Thank you in advance.
Re: Suggestions for the best way to tie down a load
My first question would be, do you have a tailbox rack? A 25 pound bag would probably not fit in a tailbox, though you could experiment at home to see. However, you COULD put a milk crate on the rack, and it should work. Don't try to carry it by itself as the bag is quite slippery. Boxes work well, even cardboard boxes.
Brice
Post by Brice »
Mel46 wrote:My first question would be, do you have a tailbox rack? A 25 pound bag would probably not fit in a tailbox,
Yes, I can remove the tailbox and use the rack. I should have mentioned that.
I can also place the bag into a duffel bag that has handles and loops.
Year: 18 300 xmax
Get a cargo net for motorcycles off Amazon…
https://www.amazon.com/gp/product/B0022 ... UTF8&psc=1
‘15 PCX build thread here:
salsa
Color: Forza red
Post by salsa »
You might be able to fit it under the seat, especially if you divided it up into 2 bags. Just take a small garbage bag along and some twist ties.
It is a little late now, since you are already about to pick up your parcel, but you should read this thread I created long ago. It works well. I have used these multiple times with no problems, and they tie back out of the way when not in use.
viewtopic.php?f=2&t=2065
Brice
Post by Brice »
I didn't get it this time, but I'm glad I asked, I'm hoping there will be a next time!
Thanks for the suggestions and links. Y'all are great.
