Hi,
I have a Forza 300 2019 and its started shuddering with less than 5k on it, its now put away for the winter and I wanted to clean it all out inside as I assume its the belt dust from riding like a granny, would anyone know the torque settings for the clutch,variator nut and the big 41mm one and also the outer casing bolts?.
Its a good scoot but my wing mirrors vibrate while riding so i had to put a piece of plastic in there and that cured it and now the fuel flap wont open when i press the button unless I press the plastic just behind the hinge, so far not impressed on the build quality, yes it would be fixed under warranty but its a day taking it in and if they agree with the fault its another day or two while they fix it so i would sooner do it myself and service it at the same time.
Thanks if an any one has the torque specs.
Mark
Torque Settings
- easyrider
- Color: blk
Re: Torque Settings
Clutch driven pulley nut ...58
clutch outer nut ...55
drive pulley face bolt ...61
case bolt ..18
values in Foot Lbs.
case bolt ..18
values in Foot Lbs.
- Color: Blue
Re: Torque Settings
nice one, thanks, 18ftlbs for casing bolts, wouldn't have thought that being so small
- easyrider
- Color: blk
Re: Torque Settings
I never torque those small fasteners.. a good hand tight to snug is all that is needed.
- Color: Blue
Re: Torque Settings
great, I take it the nut sizes are 14mm 17mm and 41mm?.
Re: Torque Settings
I hate torquing bolts, I am dyslexic and sometimes put the wrong numbers into my wrench without thinking.
I hate it when it goes tight, tight, tight, oh shit now loose, thread stripped. Or I snap the bolt off. Chinese steel is made of rust they pull out of the rivers according to one documentary.
