@Foggyhelmet
My '13 model does 108-114 GPS kmph depending on conditions all the time.
I run a Malossi Multivar 2000 with 10.5gr rollers, a washable filter and the snorkel removed. My belt has about 10k km on it, and I'm running slightly fatter (110/70 at the front and 120/70 tires at the back).
Will report about the top speed of my new 2015 model with an all motor build.
PCX top speed
Re: PCX top speed
Pcx 125 / 2014 (led) Owner here. Previously had a V1 (non esp). My theory is that the led model has more drag and worse Cx than previous esp due to bigger frontal surface. This model is most difficult modding for top speed it seems (without resorting to BBK).
People complain about top speed in all the forums i read, the French , the Dutch, the Portuguese, the German. I think the bike is simply not easy to mod for this. The various pcx iterations have improved acceleration but not top speed.
I had a malossi on my previous led model and was surprised how good the stock is while reverting lately except from the strange lag at take off. Recently tried dr pulley sliders 13Gr on stock and took them away after two weeks. The bike felt too linear, and really too boring. (found out after initial disappointment there is a post in Dr pulley support forum from owner of german pcx forum saying not to use sliders only the rollers in led model because it makes belt drive to high and there an issue of clearance with new double rigged belts)
Figures i have is consumption on daily commuting in city: 2,2/2,3 L stock-2,5L Dr pulley sliders on stock- 2,7 L Malossi vario (10,5 gr). I rarely use top speed, say once every three-four month so YMMV.
I am also experimenting with a GPR furore exhaust lately, not happy about the fact it's touching and melting my radiator cover ( long story with factory return , i will post in due time) but it does bring quite good improvements in the 50-70 km/h range or 70-90 acceleration ( top speed ? dunno, not been higher since) depending on the weights in the vario. With the pulleys it felt like a compressor kicking in at 50, with stock it's effect is more pronounced higher up. Next step for me will be lighter rollers
Unfortunately NCY parts are nowhere to be seen here in benelux, i would like to test them. Importing them will just break the bank with taxes
- Color: Candy red
Re: PCX top speed
I have a 2011 PCX125. My bike tops out at 61-62 Mph indicated.
I have a NCY variator, 13g rollers and drive face on order. I hope to be able to do 65 mph.
- Color: WHITE
Re: PCX top speed
I DON'T SEE ANY NEED FOR SPEED OVER 90 OR 100, GIVEN THE SMALL TYRE... SEVERELY COMPROMISE SAFETY...
MAYBE YOU FOLKS HAVE BETTER TARMAC ROAD THAN MINE HERE IN SOUTH CHINA...
- Year: 18 300 xmax
Re: PCX top speed
Turn off Your caps.....
‘15 PCX build thread here:
Re: PCX top speed
he can't turn them off, it's lost in translation on his keyboardJge64 wrote:Turn off Your caps.....
- kb.jpg (201.58 KiB) Viewed 947 times
