Are there any UK Forza owners out there?
- Darth Emma
Re: Are there any UK Forza owners out there?
BEAUTIFUL! Enjoy your new ride.
Rides 2014 Honda Forza, 2012 Honda Ruckus
Darth Emma wrote:BEAUTIFUL! Enjoy your new ride.
Thanks Darth Emma - I have so far, though she's a LITTLE on the slow side but will speed up I know!! Ride safe
NOT a happy bunny now! I have a problem with the 'cubihole' lock switch on my Forza - you know, the button on the left that is MEANT to unlock the cubihole - no longer working, switch completely 'loose' and cannot open the cubihole! Peed off. Anyone out there had the same problem?
- 2013-11-18 17.03.00.jpg (152.59 KiB) Viewed 1205 times
I am sorry your having problems with your new Forza. I wish you the best of luck. As far as fixing it I dont have a clue.
~Cheap_Ride~ wrote:I am sorry your having problems with your new Forza. I wish you the best of luck. As far as fixing it I dont have a clue.
Thanks for that. It's just VERY annoying - I've had it less than a week .... I'm taking it to my local Honda dealer tomorrow and hope they can fix it easily enough!!
Best
Toria
- Darth Emma
I'm sure you've done this, but I'll ask anyway...toria wrote:NOT a happy bunny now! I have a problem with the 'cubihole' lock switch on my Forza - you know, the button on the left that is MEANT to unlock the cubihole - no longer working, switch completely 'loose' and cannot open the cubihole! Peed off. Anyone out there had the same problem?
Do you have the key in the ignition set to the "unlock" position?
When you press the switch, you have to feel that "click" and then it opens.
If it's not working right, then take it to the dealer.
Sorry to hear it's giving you trouble. I've had no issues with mine.
Edit: We posted at the same time. I see you're planning to take it to the dealer. I'm sure they'll fix you up in no time. Good excuse to go for a ride!
Thanks for your message. Yes, the key is in the right unlock position. Hopefully Blade Honda will sort it tomorrow.
Thanks for your message. Yes, the key is in the right unlock position. Hopefully Blade Honda will sort it tomorrow.Darth Emma wrote:I'm sure you've done this, but I'll ask anyway...toria wrote:NOT a happy bunny now! I have a problem with the 'cubihole' lock switch on my Forza - you know, the button on the left that is MEANT to unlock the cubihole - no longer working, switch completely 'loose' and cannot open the cubihole! Peed off. Anyone out there had the same problem?
The switch is just 'loose' - it's almost like it's popped out of its housing though not sure if that's possible and if it is, why it's done it. Grrrr, it's fab otherwise though got drenched on my way from home, nasty ride, couldn't see diddly-squat!!Darth Emma wrote:I'm sure you've done this, but I'll ask anyway...toria wrote:NOT a happy bunny now! I have a problem with the 'cubihole' lock switch on my Forza - you know, the button on the left that is MEANT to unlock the cubihole - no longer working, switch completely 'loose' and cannot open the cubihole! Peed off. Anyone out there had the same problem?
Just in case anyone is having problems fitting their helmet (!) under the seat, here is a picture of my flip top helmet (and my head's not small).
- Helmet under seat.jpg (258.32 KiB) Viewed 1200 times
gn2 wrote:Had mine since 12 September, 2,000 miles on the clock now.
I find it very comfortable, handling is excellent, very stable, easy to ride at low speed, good at getting through gaps, economy is good at circa 79mpg average and it will do 70mph uphill into a headwind without any problem.
And a bottle of wine will fit in the left fairing pocket.
I can thoroughly recommend it.
I'd be careful about putting anything remotely heavy in the left fairing pocket - I HAVEN'T BUT the switch to unlock it is ALREADY broken and I can therefore not use it. The manual says that you shouldn't put anything over 1.5kg in weight in there so I suspect a bottle of vino may NOT be a good move! It makes me worry that the switch for the fuel and seat will go too - that would be even more disastrous! Hey ho, my local dealer in the UK are going to sort out the fairing pocket at its first service BUT it means I'll be without my bike for at least a day as they're going to have to strip it down to get at the problem and then order in parts if necessary!! What a pain in the proverbial!!
Ill be joining the fray within a week - yay!
V4 TRV wrote:Ill be joining the fray within a week - yay!
Excellent! Hope you enjoy it. What colour are you getting? Ride safe
Black for me too. Will post a pic when I get all my bits put on it. Left the PCX in today for the grips,running lights etc to be transferred over. Hope to be on the road by Friday.
it sounds like your new forza is going to be very well equipped i look forward to seeing the photographs. Right safely and enjoyV4 TRV wrote:Black for me too. Will post a pic when I get all my bits put on it. Left the PCX in today for the grips,running lights etc to be transferred over. Hope to be on the road by Friday.
How much?
toria wrote:it sounds like your new forza is going to be very well equipped i look forward to seeing the photographs. Right safely and enjoyV4 TRV wrote:Black for me too. Will post a pic when I get all my bits put on it. Left the PCX in today for the grips,running lights etc to be transferred over. Hope to be on the road by Friday.
..... that should have been 'RIDE' safely - blinking predictive text on my mobile!! Enjoy
Toria-
Did you ever get the switch problem sorted out? Hope it is fixed, and you are enjoying your ride...
MichRocks wrote:Toria-
Not yet but taking her in for her first service today so they're going to look at it and hopefully resolve in the next week! Keep your fingers crossed for me - most certainly enjoying the ride, apart from when it's peeing down with rain!!
Best
Toria
Yey, fairing box problem resolved, was just that the cable hadn't been fitted properly at the factory! First run in service done and now purring like a kitten!!
