Best drive face option?
logepoge1
Re: Best drive face option?
Post by logepoge1 »
dem0nk1d wrote:NCY Variator with NCY Drive Face 13g rollers i think... Bored stock out exhaust, pod air filter directly on the throttle body, down hill ninja tuck...
What kind of pod filter?
dem0nk1d
Post by dem0nk1d »
i'm using a pod filter from my pitbike engine off the Honda Passport. It's this one right here...
"40MM AIR FILTER"
http://www.amazon.com/40MM-FILTER-HONDA ... B007Q4AAQW
logepoge1
Post by logepoge1 »
How'd you install it? I read something about the vacuum for the belt housing
Mgalutia88
Year: 2013 PCX 150
Post by Mgalutia88 »
No vacuum on our belt housing. Simple and straight forward.
logepoge1
Post by logepoge1 »
dem0nk1d wrote:i'm using a pod filter from my pitbike engine off the Honda Passport. It's this one right here...
"40MM AIR FILTER"
Do you have picture of it installed
logepoge1
Post by logepoge1 »
This is my installation. I have a question though. Where does the hose below go?
It was connected here:
logepoge1
Post by logepoge1 »
Okay the captions are kinda off because of tapatalk being weird but I'm sure you can figure it out
Mgalutia88
Year: 2013 PCX 150
That would be the valve cover vacuum line. Install a breather on the end of the vacuum line or directly on the valve cover I needed. The further the better simply because of the oil coming into the airbox. In theory less or no oil is good but also vacuum on the crankcase is a good thing. We use to just Ben. The crankcase to atmosphere but the EPA doesn't seem to like that too much hence we have a catalyst in our exhausts.
logepoge1
Post by logepoge1 »
Okay. I decided to leave the air box in same position but hair disconnected. So will that vacuum line be fine just kept connected to the air box?
Mgalutia88
Year: 2013 PCX 150
i dont see why not. The airbox has a oil drain on it.
logepoge1
Post by logepoge1 »
Wow the sound difference. Has a bit of lag at takeoff and no noticeable speed gains but maybe I need to reset computer?
mikelx5
Post by mikelx5 »
if you have only done the filter no exhaust it can hurt your bottom so lighten your wieghts to get you higher in your rpm range faster
DISOBEDIENCE CREW
logepoge1
Post by logepoge1 »
I have 10g sliders on
dasshreddar
Year: forzaruckuspcx
Post by dasshreddar »
You need to get an exhaust to feel any gains with that filter.
And its not a vacuum line, its just a breather/vent line.
I just have a L shaped hose(like the one in your hand pic) connected to the valve cover on mine, and of course NO airbox.
logepoge1
Post by logepoge1 »
What exhaust is recommended?
logepoge1
Post by logepoge1 »
I think I'm fine without performance increase. I like the sound. Sorry to hijack this thread
mikelx5
Post by mikelx5 »
wow my bike must be slow lol im lightening my weights today
DISOBEDIENCE CREW
Mgalutia88
Year: 2013 PCX 150
Suggested exhaust? Takegawa. Any of them.
