Page 2 of 2
Re: Belt Case Corrosion !
Posted: Sun Sep 19, 2021 1:54 pm
by Brava210
The cover is still just hiding the corrosion underneath, as standard
Posted: Sun Sep 19, 2021 1:59 pm
by Brava210
I have managed to wire wheel all the corrosion off the casing.
I'm gonna take the rear wheel out tomorrow and wire wheel the casing there, waxoyl it and hope it doesn't catch fire
Posted: Sun Sep 19, 2021 7:16 pm
by canthai
Brava210 wrote: ↑Sun Sep 19, 2021 1:54 pm
The corrosion is surface only. No issues.
Posted: Sun Sep 19, 2021 7:34 pm
by davenowherejones
Bad engineering
Posted: Mon Sep 20, 2021 2:27 am
by canthai
Bull - blame the environment. All aluminum corrodes unless protected. Cover in clear coat, anodize, etc.
You keep on saying "Bad Engineering, a Design Flaw, yada yada yada "
And then post how many Km's your bike has travelled.
You can't have it both ways.
If it bothers you, fix it.
Posted: Mon Sep 20, 2021 12:47 pm
by Brava210
I have decided on Silver VHT paint for the casing, as Waxoyl says Max Temp 50 degrees
It looks OK, weather it will make any difference I don't know
