Stop/brake light not working 2013 PCX
Re: Stop/brake light not working 2013 PCX
Man, you guys ran this poor guy all over the neighborhood. .....missing the most likely fix. New little plastic brake light switch seemed pretty obvious.
Happens to scoots frequently.
More (in this case) is better - gaw head, "Show" him "the part" fish.
Within this thread I added a link for the op. I'm wondering if you clicked/read through it. Re: my brake light switch cable part #14(on my 2015, that I replaced) awhile back.
SHOWN is for Model 2013
2013 PCX brake light switch cable.jpg (65.38 KiB) Viewed 736 times
Stay well everyone
kabutomz
Post by kabutomz »
WooHoo.
It didn't work, but i tested another light bulb just in case and it worked.
Thanks so much for your help everybody.
It was the switch.
kabutomz
Post by kabutomz »
Showing the switch i replaced
Switch it was. Mine the cable. Very cool. Good thread!
Folks who have brake light failure can search and find this thread/w/result too. Cheers, beers!! (I certainly did (o;
And....You Did!! :P
P.S. Thanks for adding your location. Be well, be safe
Peter Panini
Color: Gold
Post by Peter Panini »
I noticed today that my brake light is not functioning - I generally have a look around to check all lights are functioning as they should every other day or so.
Replaced switches about a month ago.
I get the feeling it's a fuse or a loose connection somewhere (lots of bumpy roads in Vietnam).
Off to Honda tomorrow..
Edit: I looked in the rear brake housing - one filament in the bulb is shot. Should be a cheap-as-chips fix.
